07-06-2014, 01:16 AM | #3576 |
Re: What Did You Do With Your Truck Today ?
More work on the bed sides, just minor stuff. Fleetside spears are really cool, but a PITA to get the ridge straight... Also hung the doors and got them close. Going to do the fenders before doing anymore adjusting. Did find the driver step sill installed high from the factory at the front so door gap at the bottom is off a little. BFH an sturdy oak block moved it a little. Not enough for me to worry about, it did fine for 25 years, next guy can get neurotic about it! Body lines are lining up fine which is what stands out the most.
07-06-2014, 02:32 PM | #3577 |
Took the Newlyweds for a carriage ride.
07-06-2014, 11:10 PM | #3578 | |
07-06-2014, 11:31 PM | #3579 |
Got my seat in after having it redone! Not for everybody but I like it! photobucket.com/user/crime_inc/media/imagejpg2.jpg.html][/URL]
07-08-2014, 12:10 AM | #3580 |
Got the steering box mounted!!!!
07-08-2014, 12:58 AM | #3581 |
i dig the seat! is that a rebuild original or out of something else?
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels |
07-08-2014, 02:48 AM | #3582 |
Am I missing something? With the steering box mounted on top of the frame rail, the arm will move up&down instead of side to side. What other linkage are you going to ad?
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
07-08-2014, 07:01 AM | #3583 |
07-08-2014, 08:20 AM | #3584 |
Knocking down 5 layers of paint from previous owners.
I made this silly looking rolling cab cart to make it easy moving the cab in and out of the garage. |
07-08-2014, 01:06 PM | #3585 |
Seat looks killer man!
Cheers, Chris 1951 Chevrolet 3100 Pick up |
07-08-2014, 01:12 PM | #3586 |
Thanks Half Baked appreciate that! I know this style isn't for everybody but it is getting a warm reception.
07-08-2014, 04:46 PM | #3587 |
Put wheels on to check fit. Finished door.
07-08-2014, 09:49 PM | #3588 | |
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
07-08-2014, 11:16 PM | #3589 |
Dan I seen the picture you posted in the past and I felt the same way, that's what inspired me to come up with my own design. I appreciate the kind words.
07-09-2014, 11:59 AM | #3590 |
I am headed to Mexico in November, I'll have to keep my eyes out for a new cover for my seat!
07-09-2014, 04:17 PM | #3591 |
I finished up my new front brake lines and bled them today. Got good pedal and was hoping to neighborhood-drive it today but didn't happen. Maybe tomorrow. I did find the best and least messiest way to add fluid to my CPP under floor master and maybe it will help someone. I impulse bought a five pack of these bottles at Harbour Frt a few years back. I put brake fluid in one, screwed the nozzle off, and stuck on the hose and it worked great. It's easy to top the mc off because the bottle doesn't deliver too much volume per squeeze of the trigger and the flow stops when you release it. I found it more controllable than a squeeze bottle with a hose on it.
BTW, the saddle blanket seats in the previous posts look good. I like them both. |
07-09-2014, 05:59 PM | #3592 | |
07-09-2014, 07:23 PM | #3593 |
good idea russell thanks for sharing
both seats look good !!! |
07-09-2014, 11:32 PM | #3594 |
I just wanted to add in, i think that seat is REALLY sharp. Not only does it add a little color, but the fact that it looks like it's a part of the seat, and not some sloppy seat cover really adds to the fact. (although I like those covers too. Everything has their place)
Ha ha yeah that was the original pitman arm that I never quite took off all the way. I'm going to have the pitman arm vertical, with a drag link between the steering and pitman arms. It'll be real similar to the original system, except the box will be in front of the axle as opposed to behind. |
07-13-2014, 02:02 PM | #3595 |
Cut the step loose and pushed it down, sill stayed level and parallel with the door bottom. Still needs welded and hammer and dolly work and door gap set but much closer.
07-13-2014, 06:26 PM | #3596 |
A320 Pilot/USAF Retired
Gave my 57 a facelift!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
07-13-2014, 07:04 PM | #3597 |
My dad waited 38yrs to give me this wrench.!
I'm guessing he thought i was old enough not to distroy it...? at least thats what i 'm thinking . . . . I calling this.... " How many thing are just wrong with this scene"...... . It is not lost on me All 6 wheels are off and the truck is on jack stand/ assort, wood blox in a dirt drive way on a hill working on widow makers and surrounded by very dry grass no fire extingisher about 2 feet away from a propane tank on one side Oxy/Acetylene set on the other Busting my hump on a 50 yr old wrench with a 4ft cheeter . when will the fun stop.? . the rims got alittle hot . . . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
07-13-2014, 07:16 PM | #3598 |
but in the end i had a vision and it all worked out for the day
. No lives were lost . . two wheel cylinders per wheel ..Means two adjusters . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 Last edited by Softpatch; 07-13-2014 at 07:18 PM. Reason: spelln |
07-13-2014, 07:22 PM | #3599 |
I like old tools and that lug wrench looks interesting to me. It's actually called a Shock wrench. Here's a link to a tool vendor that gives a little info about it. I first assumed that you hit the ends with a hammer to loosen the lugs but you just spin the arm and the weight of the ends acts like an impact wrench.
http://inlandvalleytoolsupply.com/ken-tool.pdf |
07-13-2014, 08:05 PM | #3600 | |
.thanks for the Tech info R.A..very interesting. I did use a large hammer on it. The wheels Nut's/studs have been soaking for days but could not penetrate the wheel studs. I even had to use heat to first take the lug nuts off then after no luck with a hammer and the "Kem Tool' more heat and a large pipe wrench with a cheater bar & lots of heat and my fat arse it finally broke loose I'm beat up .. Tomorow I'll take the shoe to be relined ......Sp . . .
