Old 07-14-2014, 07:01 PM   #1
hotrodder
What 5 lug rear axle do you guys think
I am wanting to change the rear end in my 67 to 5 lug instead of 6. What years will interchange without too much modifaction?
hotrodder is offline   Reply With Quote
Old 07-14-2014, 07:48 PM   #2
Willys47
Willys47's Avatar
Re: What 5 lug rear axle do you guys think
I would say the easy way would be to just change the axles. they make a axle to change from the 6 to the 5 lug I think Moser has them
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 07-14-2014, 07:59 PM   #3
Zeroman
Zeroman's Avatar
67-69 and some 70 model differentials are about 1/2" shorter per side compared to the 71-72 5 lug differentials. I know from experience as I am going through the same conversion.
You can buy conversion axles from some suppliers. These would be the shorter, correct length for your differential tubes, and they would be 5 lug.
You can have your 6 lug axles welded up and re-drilled to 5 lug.
You can have 5 lug axles shortened to the 6 lug axle length and re-splined.
All these options require you to buy the correct drums, etc.
Or, you can buy a 71-72 rear end with all of the correct axles, brakes, etc., and have it rebuilt and painted. You might even be able to select your drive ratio, or even put a posi chunk in it.
I am going the whole rear end route as I can buy it rebuilt, rebuild the brakes, and do the swap in a day.
Your mileage may vary.
Zeroman is offline   Reply With Quote
Old 07-14-2014, 10:37 PM   #4
67shortstepside
redrill your axles !!
67shortstepside is offline   Reply With Quote
Old 07-14-2014, 11:38 PM   #5
Ozzy2013
Ozzy2013's Avatar
Has anyone redrilled your axles?Do they have to have the old holes welded?I have to do the same thing with my 68 thanks Oz
Ozzy2013 is offline   Reply With Quote
Old 07-15-2014, 12:20 AM   #6
67shortstepside
had mine redrilled and it was done good
Old 07-15-2014, 12:35 AM   #7
no1udknow
no1udknow's Avatar
I am also interested in redrill info. I am torn right now between 5 and 6 lug conversion. I have all new front end disk brake parts, but they are 5 lug. So either I buy new rotors, or I redrill rears. I'm leaning toward redrilling because I want to run some 5 spoke rally rims or cragars.
no1udknow is offline   Reply With Quote
Old 07-15-2014, 12:45 AM   #8
no1udknow
no1udknow's Avatar
There is a local shop here in Sacramento called Jaws Gear and Axle' they have 5 lug conversion axles for $130 each. Most places I have seen are double that
http://www.jawsgear.com/Axle_Shafts-Chevy-Truck/
Old 07-15-2014, 11:29 AM   #9
Steve Cole
I bought my Moser 5 lug axles for around $260 from Summit w/ free shipping. The swap only took about 1 hour and most of that was scraping the old gasket off the differential cover!
Steve Cole is offline   Reply With Quote
Old 07-15-2014, 02:39 PM   #10
kamikazekyle05
kamikazekyle05's Avatar
Exactly what I did
kamikazekyle05 is offline   Reply With Quote
Old 07-15-2014, 03:59 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Buy new axles.
Keith
Convert to disc brakes.
Old 06-10-2015, 04:49 PM   #12
mattarnold42
Doing a 5-lug conversion on my '70 C10 as well. For the rear, i just need axles and drums? All the brake hardware the same '70-'71?
mattarnold42 is offline   Reply With Quote
Old 06-10-2015, 05:33 PM   #13
mattarnold42
Really confused here, I have the wide rear end that came in the '70 C10, if I get the 5 lug conversion axles, would i technically have a '71-'72 rear end? any help shedding some light on this would be great. I'm trying to get everything ordered for the conversion/drop, don't want to miss anything.
Old 06-10-2015, 09:36 PM   #14
hugger6933
The $130 axles in the above site are now $185
hugger6933 is offline   Reply With Quote
Old 06-11-2015, 10:08 AM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
No... they are "conversion" axles that are the correct length for your 1967 12 bolt. They will have 5 lugs drilled in the flange instead of 6. Basically same as a stock 6 lug axle that has been drilled for 5 lugs.
If you ordered stock style 1971-72 axles with 5 lugs, they would be the wrong length for your 1967.
Clear as mud?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-11-2015, 11:05 AM   #16
Steve Cole
If your 70' model rear end is the wider version then the 5 lug axles from a 71-72 should fit no problem. They only made two different width rear ends so if yours is the wider one you're good.
Old 06-11-2015, 11:52 AM   #17
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
We used the rear end out of the (75 - 76 ?) suburban which was the donor for my engine & trans.
Easy install & instant 5 lugs matching the whole front end swapped out of same vehicle.
68shortstep is offline   Reply With Quote
