Old 07-15-2014, 09:32 AM   #1
Tukn22z
Wiring issue
So i am finishing up my ls1 swap and i tried to start it for the first time and i have a small wiring issue with my fuel pump. For some reason my fuel pump turns on when i turn on my headlights. Does anyone have any suggestions where i should look first? Did i hook up my cranking signal wire to the wrong wire on the ignition switch? thanks
Tukn22z is offline   Reply With Quote
Old 07-15-2014, 12:48 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Wiring issue
Did you put the signal wire for the fuel pump to the headlight relay instead of its fuel pump relay?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-15-2014, 01:38 PM   #3
Tukn22z
Re: Wiring issue
i used Current performance's fuse box and put the signal wire to the ignition. I ran that wire to the purple ON wire on the ignition switch. Im pretty sure i have this on the wrong wire and it needs to go to the pink START wire on the ignition switch. Does this sound correct?
Old 07-15-2014, 07:00 PM   #4
Smurfeh
Re: Wiring issue
Yeah bud.. the pink/black wire will go to your ignition wire
(Solid pink 10AWG) that used to go to your distributor (assuming its an 80's truck you're doing don't know about earlier models.) and the grey wire will go directly to your fuel pump. its a two wire hook up just to start and run the engine.. but you need to connect the TCC wire before you try to move it under its own power.
Smurfeh is offline   Reply With Quote
