07-15-2014, 09:56 PM | #1 |
common repairs/upgrades to do while engine is out
I searched and couldn't really find any thread with this info so thought I would start one.
I have a 4.8 about to go into my 50 Chevy. What are the common things to repair, replace or upgrade while its out? Are there any sensors that go out that would be easier to do now instead of once its in? Gaskets? Common leaks to take care of? Stuff like that. I intend on replacing the water pump while its out. Going to put a swivel water neck and tap the heater ports for some 90 degree fittings so I don't have to mess around with the inner fenders to much. Thanks for your help, Chad |
07-16-2014, 12:11 AM | #2 |
meowMEOWmeowMEOW
Re: common repairs/upgrades to do while engine is out
Oil pump and pickup w o ring when swapping the oil pan anyway (which I imagine you'll be doing for the swap).
Waterpump gaskets. Clean the injectors and rail in seafoam, replace o-rings if needed. If you think you want a cam, do it now while the engines out, and all the timing stuff is simple to get at. Its MUCH easier taking a crank pulley off when its on an engine stand.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-16-2014, 03:21 AM | #3 |
Thanks. I am replacing the pan with the f-body one for a little more clearance. I will do the pump and o ring and will pull the injectors and rail to get them cleaned out.
I don't think I will be doing a cam. Don't feel the need. I am a low, slow and quiet kind of guy. Any other "standard repairs" I should look out for? Thanks, Chad Last edited by dante81_98; 07-16-2014 at 03:44 AM. |
07-16-2014, 11:21 AM | #4 |
Check the rear main seal, although if it's not leaking I would only replace it for a high mileage engine.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
07-16-2014, 08:27 PM | #5 |
Fabricate till you "puke"
Yes! Also as a note, you can get the rear cover, complete with seal,gasket, & bolts....for about what you would pay for the gasket & seal ? From the chevy dealer, the cover/ seal comes with a plastic sleeve to orient the seal lips properly (no fuss, no mess)! Just clean the rear of the block, the plastic cup "locates" the seal to the crankshaft? Just push the cover on, & add bolts...You can use the stock pan, as a tool to locate the bottom of the rear cover....pretty slick! While you are in there, you might replace the "barbell", as it does make the seal on the oil gallery? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-16-2014, 08:44 PM | #6 |
KNOCK SENSORS and harness to them.
07-16-2014, 09:14 PM | #7 | |
I am running the truck oil pan. You probably only need the f-body pan if you plan to bag the truck and lay frame. Where you should be concerned about clearance is front to back if you aren't recessing your firewall. The truck accessories stick too far out and won't leave room for a fan. Some guys have done the pusher fan with mixed results. I am using GTO accessories which are closer to the block and share the same spacing as the f-body accessories.
My 1950 Chevy build |
07-16-2014, 09:42 PM | #8 |
Valve Springs.
07-17-2014, 12:17 AM | #9 |
Thanks for all the replies. The motor has 115K on it and came from a highly recommended and reviewed yard up in the northeast.
The engine and trans is just set in there for now to get them mocked up before we make some mounts. Its bagged and lays on the ground. It has the truck pan on it now and its just off the ground. I am going to put the F-body pan on just so I have some safety clearance. I don't intend on recessing the firewall. I am going to mock up the radiator, fan and shroud this weekend and will see what I can come up with. It looks like there is enough room, but we will see. |
07-18-2014, 03:01 AM | #10 |
Yes! one sharp old man I will, lay it down, how it goes....A bad set of valve springs, will "spoil" the sweetest overhaul, that you have done? longhorn
07-21-2014, 11:13 PM | #11 |
well it was close with the fan and shroud I had, but ultimately we needed to move the engine backa little. I cut the firewall out and mocked it up. Ended up moving the engine back a little further than was needed just to give some extra room. Need to find some headers that will work now. Need something that hugs pretty tight to the block. Trying to find some tbss manifolds. We will see what we can find that will fit.
07-22-2014, 05:54 AM | #12 |
If you want something that tucks tight to the block...Hooker streetrod shorties(LS). They don't dump center, like the gen I shorties....but about under the 3rd port? Nice build! Did you clip the front, or opt for a mustang II ? Longhorn
07-22-2014, 11:40 AM | #13 | |
The suspension is all custom. We used the stock frame. The spindle and brakes are from a 95 Chevy pickup. The control arms and bag mounts are custom made. The steering is a power rack from a thunderbird. |
07-23-2014, 02:03 PM | #14 |
If you don't need tube headers specifically, 2010 and later Camaro manifolds have a lot of clearance and a straight down exit. I'm running them on my '72 C10.
07-23-2014, 03:20 PM | #15 |
I will look into those too. I don't need tube headers. Factory manifolds will be fine for me.
