Old 07-16-2014, 02:35 PM   #1
CAChevy
Computer Controlled HEI Base Timing
The CA emissions sticker (XFF) on my '84 w/original 305 says to set base timing @ 6 deg. That seems a bit low to me. I was thinking more along the lines of 10 deg.
I've swapped in a 350 keeping all the smog/computer controlled items. The cam I'm running is a Comp 12-235-2.
I'm curious what base timing you guys with the electronic HEI, CCC Quadrajet and ECM with O2 sensor are running?
CAChevy is offline   Reply With Quote
Old 07-16-2014, 03:51 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Computer Controlled HEI Base Timing
I'm running 8 deg. on my 83 with the stock 305, runs fine, did you disconnect the 4 pin wire off the distributor when you timed it?, you'll be surprised how many don't when they time the motor
Malo83 is offline   Reply With Quote
Old 07-16-2014, 04:34 PM   #3
Just call me Sean
Just call me Sean's Avatar
You don't disconnect the four pin plug to time it. You unplug the single wire plug which is tan with a black stripe, I don't remember the location offhand but I think it's by the main firewall plug.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 07-16-2014, 06:19 PM   #4
beamn7
You do disconnect the 4 wire plug on a computer controlled, CA emissioned HEI distributor. The plug is a weatherpack connector, has approx a 6-8 inch lead from the distributor and is on the pass. side of the engine.
The Tan wire with the black tracer is a distributor on a TBI equipped truck with a non-integrated coil.
I run 8 deg also. Remember, here in CA you can go plus or minus 3 deg on the timing and still be legal for your smog inspection.
beamn7 is offline   Reply With Quote
Old 07-16-2014, 06:28 PM   #5
CAChevy
I found out pretty quick that I needed to unplug the distributor from the ECM when I first went to time it. You guys are correct, it is a 4 pin molex plug. I was seriously frustrated trying to adjust it with the computer trying to readjust it.
If I can get away with +/- 3 deg with the smog nazis I think I'll try 9 and see what happens.
Did you guys notice any difference changing it a few degrees BTDC?
Old 07-16-2014, 06:41 PM   #6
beamn7
Hard for me to say if I noticed any difference as I up'd mine after building the 350 for it and yanking the tired 305 out. Malo might have better input as he has the 305 still too... One thing to keep in mind is the timing effects HC and NOX also. If your truck is border line out the tailpipe, upping it too much may fail it... Make sure your idle is set also to plus or minus 300 rpm from factory specs after adjusting the timing. I run about 650-700 vs stock of 550.
Seems like they keep tightening our limits out here... think they want our 'ol trucks off the road!
Old 07-16-2014, 06:44 PM   #7
Just call me Sean
Them California cars get me every time.
Old 07-16-2014, 06:46 PM   #8
beamn7
LOL, Tell me about it!
Old 07-17-2014, 03:41 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
No difference to me, truck ran the same, but like beamn7 said, changing the timing could affect the outcome of the smog test, I leave mine at 8 deg and the truck runs fine plus she hasn't failed a smog test yet
