Porpotioning Valve
ok... so I've done a bit of reading. Disk / Drum setup... 3/16 lines to the front from front reservoir - 1/4 lines to the rear block and then 3/16 to each drum. Ok... I was provided a McGaughy's proportioning valve for the rear and I understand that's to keep the rear from locking up - but the input and output on the valve itself are 3/16 so now I'm wondering if I go down to 3/16 to go through the valve why am I not running 3/16 all the way back at that point? Am I making sense here?
64 Step Side - The Mistress |
![]() Join Date: Mar 2005
Re: Porpotioning Valve
I'm going through the exact same thing right now. I had already bent up my rear 1/4" line, and then decided to use a Wildwood proportioning valve like you've got. I asked all of my buddies who own hot rod shops and they suggested to just use 3/16" line all the way through the braking system (front and rear). If you're using a factory style GM master cylinder, then you'll have to get the 3/16" line nuts for the 9/16-18 and 7/16-20 line connections at the front and rear ports. GM tried to make all of these connections fool proof by making them all different sizes, but that makes it a pain when you're building a new system from scratch. I'm going to be running to the local NAPA store in a few minutes to see if they have these line nuts. If they don't, then I'll be ordering some on-line.
I'll keep you posted on what I find out. It might same you some headaches.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
I went to the local NAPA, and they don't carry the 9/16-18 and 7/16-20 line fittings. I went to the speed shop in Hesperia, and they had the fittings for $1 each. Not a bad deal at all. I spent the rest of the evening bending brake lines.
Thanks man... think I'm going to follow suit - 3/16 all the way back. Thanks for the insight... more brake line bending can't wait lol
If you can't find the master cylinder fittings in your area, let me know.
Thanks man - I really appreciate that... hope to get out to napa tonight and see what I can find.
