Old 01-12-2004, 10:52 PM   #1
69 air cab
sandblasting question?
I keep hearing that I should not sandblast my truck (currently in 1000 parts) because if gets the metal out of shape. If I sandblasted the fender and doors and not the other part would that just give me more pain later? I have no way to bead blast.
69 air cab is offline   Reply With Quote
Old 01-12-2004, 11:02 PM   #2
krazy_texan
krazy_texan's Avatar
i would have stuff like the frame sand blasted as for body parts i would have them media blasted, it causes less distortion to the metal
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-12-2004, 11:05 PM   #3
Bernie
If you get someone to sandblast at 1000 psi it probably would distort things. I use a 90 psi harbour freight special and have had no problems.
Bernie
Bernie is offline   Reply With Quote
Old 01-13-2004, 12:32 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Everything on my truck but the front fenders (NOS) was sandblasted. No problems at all.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-13-2004, 12:47 AM   #5
Rooster's 67
Rooster's 67's Avatar
jsut dont spray in the same area for to long it can heat the metal up to the point where it warps. keep the gun moving and feel the temp of the metal often with a bear hand and when it feels really warm move to another spot.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-13-2004, 01:59 AM   #6
Chevy Punk
Are there different "grits" of sand blasting material? if so what kind would work to quickly remove original paint off my hood?
Tx, your truck is absolutely beautiful.
Chevy Punk is offline   Reply With Quote
Old 01-13-2004, 02:03 AM   #7
Rooster's 67
there are different grits and there are different mediums ask at the sand blast place. tell them what you are doing.
Old 01-13-2004, 02:10 AM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
I'm sure you already know this, but if you are going to sandblast (or paint, etc), make sure you wear a good respirator!!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-13-2004, 03:52 AM   #9
doughby82
doughby82's Avatar
and make sure you got clean filters.i was blasting once and didnt relize i wasnt get alot of air.when i was done i took off my mask and relized my heart was racing.i know it sounds dumb,but i didnt relize it.
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 01-13-2004, 05:39 AM   #10
1972C10
1972C10's Avatar
They sell that aluminum oxide in different grits .. I just use plain on sand that i dig up at the lake it works just as good as any other sand but that aluminum oxide stuff works hella good.
1972C10 is offline   Reply With Quote
Old 01-13-2004, 11:18 AM   #11
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I'm using the same blaster with black beauty and have had no problems with distorting panels. TX Firefighter your truck is the look I had in mind for my 68, very nice!!
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 01-13-2004, 11:38 AM   #12
Yellow Cheyenne
Doors and fenders should be ok to blast, but be very careful with the hood as they are a big piece of sheet metal that doesn't really have much support. I'd probably not blast the hood (learned all of the above the hard way )
Randy
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 01-13-2004, 04:09 PM   #13
72MARIO
72MARIO's Avatar
My roof warped when I blasted it
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-13-2004, 09:52 PM   #14
69 air cab
Thanks guys..very good feedback. I think I am hearing take it easy and don't do the large surfaces. Tx Firefighter.....what's the color on your truck.........that looks just like where I am heading......really nice job.
Old 01-13-2004, 10:08 PM   #15
Low69CST
You can blast large surfaces, just keep the blaster nozzel good distance back, keep it always on the move and don't set and dig in one spot. We've always done it with no problems
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-13-2004, 10:39 PM   #16
kens71gmc
Thumbs up sandblast
Hello, had my cab and doors plastic bead blasted 70 miles away and all other parts sandblasted nearby. Bead blasting was expensive, sandblasting by far cheaper. Got excellent results from both. It all boils down to the person behind the gun. Good luck. ( my first reply, did i do alright?!)
I have been working on 71 GMC 1/2 ton, lwb. frame off resto. 383 sb/350 turbo, dynomax ceramic headers, Flowmaster 50's, summit HEI, JET tuned Q-jet, BE COOL radiator, soon to be installled Vintage Air, tank in frame, painless wiring (love it but a couple minor problems), 2 1/2 in. drop front, 3 in. drop rear. THAT ENGINE IS NOW BORN AND HOWLING LOUDLY!
kens71gmc is offline   Reply With Quote
Old 01-14-2004, 12:19 AM   #17
Solver
Solver's Avatar
I have sand blasted my box sides with no ill effects. As they say just keep moving
As a side note I agree with the others on firefighters truck and want more pics! including interior
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 01-14-2004, 01:08 AM   #18
Tx Firefighter
That orange truck turned out very disapointing to me. It was my first complete frame off resto. I learned a lot on it though. You should see my Blazer, it's the nice one. The truck I'm doing now is going to be the real deal too though.
No more casual frame up builds for me. I'm getting serious about them now.
Old 01-14-2004, 01:20 AM   #19
71swb4x4
71swb4x4's Avatar
Tx Firefighter - we would love to see your Blazer. Why don't you start a thread with some pics of your Blazer when you get time.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
