Old 07-20-2014, 04:36 PM   #1
Bagwurxc10
2004 ls swap with 99 z28 cluster
I've been doing research on z28 cluster for my ls swap. My donor 04 Silverado cluster has a white engine speed wire and the 99 z28 cluster doesnt. I'm assuming that the tach signal comes from the serial data, I just wanted to confirm or someone point me in the right direction. I've seen the same combination used.
Bagwurxc10 is offline   Reply With Quote
Old 07-20-2014, 04:59 PM   #2
Bagwurxc10
Re: 2004 ls swap with 99 z28 cluster
Here's what I got...99 z28 cluster
Old 07-20-2014, 05:02 PM   #3
Bagwurxc10
2004 4.8 drive by wire and 4l60e. I sent pcm to Brendan at lt1swap.com
Old 07-20-2014, 05:04 PM   #4
Bagwurxc10
Fabbed my own brackets for motor mounts
Old 07-20-2014, 05:06 PM   #5
Bagwurxc10
Just waiting for ups to deliver my fuel system and pcm. Hopefully I'll have it in this coming weekend or the following weekend.
Old 07-20-2014, 05:09 PM   #6
Bagwurxc10
A quick pic of the patient. ....lol
Old 07-20-2014, 05:19 PM   #7
Bagwurxc10
10" re audio in a down fire box housing the shifter and cup holders
Old 07-20-2014, 05:23 PM   #8
Bagwurxc10
My kick panels
Old 07-20-2014, 05:28 PM   #9
Andy4639
Old member
Andy4639's Avatar
Question Re: 2004 ls swap with 99 z28 cluster
My harness had the tach off the ECU direct. So yes it should. You may want to call the LS1 guys and make sure though.
Interested in the camaro cluster and how you plan to incorperate it into the dash if you have any pictures.
Nice looking ride by the way!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-20-2014, 05:31 PM   #10
Lee H
Lee H's Avatar
Great looking project.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-20-2014, 06:00 PM   #11
Bagwurxc10
I'm shooting for this. I'm using another members idea.
Old 07-20-2014, 06:05 PM   #12
Bagwurxc10
http://67-72chevytrucks.com/vboard/s...7&goto=newpost
His gauge pics are on page 1 about half way down. He did an awesome job.
Old 07-20-2014, 06:24 PM   #13
Andy4639
Old member
Andy4639's Avatar
Cool Re: 2004 ls swap with 99 z28 cluster
Yes he did. Very nice. I like that look. I wonder how he mated it to the metal dash. Did he are you weld some bolts to the back side of the metal dash are what?
I have been thinking about redoing mine and counter sinking the gauges to slant up some to see them better while driving.
Old 07-20-2014, 06:28 PM   #14
Bagwurxc10
It's anchored to the original gauge housing with L-brackets and has a lexan face.
Old 07-20-2014, 06:32 PM   #15
Bagwurxc10
The members name is imsuchaman55 has been helping me with my wiring questions. He is the member I borrowed this gauge idea from.
Old 07-20-2014, 06:44 PM   #16
jborders
jborders's Avatar
I've done the same with a 97 z28 cluster.
http://67-72chevytrucks.com/vboard/s...d.php?t=480075
jborders is offline   Reply With Quote
Old 07-20-2014, 06:45 PM   #17
jborders
jborders's Avatar
Here's the tach info if you still need it.
Old 07-20-2014, 07:33 PM   #18
Bagwurxc10
93-97 z28 clusters use a tach wire and the 98-02 clusters use the serial data wire to drive the tach...at least that's what another member told me.
Old 07-20-2014, 07:38 PM   #19
jborders
jborders's Avatar
Sounds right . Brendan's site has all the pinout info .
Old 07-20-2014, 08:07 PM   #20
Bagwurxc10
Yeah...I wish someone had all the answers for this ls swap. Brendan has done a lot of good articles on this stuff but he has never used a Silverado or a z28 cluster for a swap. We've been emailing each other on this subject. I'm doing this thread for this reason. Everyone shows the finished product, but never documented the wires used or how they got what to work. I'll do my best to keep this thread going as I figure it out. I came across the resistor idea that you posted on a ls1 site I believe. If I could get all the answers on one thread that'd be great for someone else in the future. Thanks for the reply on what solved your problem.
Old 07-20-2014, 09:00 PM   #21
jborders
jborders's Avatar
You're right it does from the the class 2 serial but not directly form the PCM . I would try it from the PCM though it might work . Pin 58 or 59 are the ones I'd try on the blue connector.
Old 07-22-2014, 10:39 AM   #22
Bagwurxc10
Talking Re: 2004 ls swap with 99 z28 cluster
Fuel system for the swap
Old 07-22-2014, 01:00 PM   #23
Low Elco
Verrrry interesting.... I wanna see what you come up with!
Low Elco is offline   Reply With Quote
Old 07-22-2014, 01:52 PM   #24
SierraMtns
SierraMtns's Avatar
Why did you pick a 4.8 over some of the other LS motors?
Nice looking stepper. Cool idea with the cluster.
SierraMtns is offline   Reply With Quote
Old 07-22-2014, 10:19 PM   #25
69sinker
69sinker's Avatar
I used an 02 Camaro cluster. Works great, I've got a lot of notes and pinouts if you need any info. Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
