Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-27-2012, 12:22 PM   #1
djrickygaz
Wiring A Stereo With No Wiring Harness
Hello does anyone know how to go about wiring an aftermarket deck in a 1960-1966 Chevy truck with no existing radio wires? I have a 1964 c10 panel that is bone stock and though it has the cutout in the dash for a radio, It has never had one installed so there is no wiring at all to connect to.
djrickygaz is offline   Reply With Quote
Old 12-27-2012, 12:29 PM   #2
MacsGTO
Re: Wiring A Stereo With No Wiring Harness
Run a constant power wire to your battery with an inline fuse (normally red). Run an ignition wire to either a switch fuseblock connection or splice into your ignition run wire (normally pink or yellow) and run a ground to appropriate spot (normally black). Then all that's left is running a positive and negative to each speaker from the radio. Pretty simple. I'm sure you could do a search for more specific info if you need it.
MacsGTO is offline   Reply With Quote
Old 12-27-2012, 12:46 PM   #3
djrickygaz
Thank you so much you helped me a lot
Old 12-27-2012, 05:17 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm with Mac, as a matter of fact, wiring a stereo in WITHOUT the factory wiring is actually easier. When I did my engine, I ended up redoing all the chassis and cab wiring as well, and I swear I lost 12 pounds of garbage that never went back in.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-19-2013, 02:51 PM   #5
boomy3555
I seem to remember a special inline EM deadener or something to that effect was required when no factory install was done. to keep the radio from buzzing/whining with the Ignition coil?
boomy3555 is offline   Reply With Quote
Old 01-19-2013, 02:55 PM   #6
tincan1966
tincan1966's Avatar
No reason to run a wire all the way to the battery for a constant 12V+. Simple tap into the cigar lighter power feed, normally an orange wire. It'll be fused in the fuse box already.
tincan1966 is offline   Reply With Quote
Old 01-19-2013, 02:55 PM   #7
tincan1966
tincan1966's Avatar
didn't mean that to sound as a correction to Macs post, simply meant as another alternative idea.
Old 07-06-2014, 01:53 AM   #8
unique760
ok I have a question about this. I wired a kenwood into a 66 c10 and ran the red one from the plug that says "stereo" on the fuse box, connected the yellow wire to the ignition and the black one the the underside of the dash. the stereo works and i like to mess with the bass setting on the deck but everytime I turn it off and turn it back on the deck goes back to demo mode and all settings reset. what would be the cause of this?
unique760 is offline   Reply With Quote
Old 07-06-2014, 08:35 AM   #9
tincan1966
tincan1966's Avatar
Sounds like you have the constant and switched power feeds reversed.
Old 07-06-2014, 11:05 AM   #10
Bhaynes702
Bhaynes702's Avatar
I agree, car stereos require two power sources 1 12vdc constant ( power all the time for memory) and 1 for operating power which is power with the key in the running position only.
Bhaynes702 is offline   Reply With Quote
Old 07-07-2014, 06:01 PM   #11
unique760
ok I switched the wires but it is still resetting . so where do I hook up the wire on the ignition? I have it on the terminal that says acc on the back of the ignition and it will save if I turn the ignition from acc to off then back but once I turn the engine over it resets again?
Old 07-20-2014, 04:54 PM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Wiring A Stereo With No Wiring Harness
Yellow wire off radio is for memory. Red is for hot. In some of these older models there is a split second the ignition will loose contact when cranking it. Make sure the yellow wire to radio stays 12 volts no matter what.
This is a generic wiring of a radio.
Also you need to check with a test light your wiring and make sure what you are hooking to.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
radio stereo wiring
