Old 07-20-2014, 04:26 PM   #1
Tennessee Bowtie
Tennessee Bowtie's Avatar
Ls swap headers????
Guys post some pictures of your engine mounts, trans crossmember, and your headers. I have a 69 c10 and I need some headers for it thy will fit with no modification. Now that I live in the real world explain what you did and how you did it to make it fit. Thank everyone.
Tennessee Bowtie is offline   Reply With Quote
Old 07-20-2014, 04:34 PM   #2
Fitz
Re: Ls swap headers????
Sanderson makes a set that actually will fit without cutting your frame. Mine isn't an LS motor and I moved the stock trans cross member back to fit the overdrive, but you get the idea how things fit.
Fitz is offline   Reply With Quote
Old 07-20-2014, 04:36 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Ls swap headers????
I did a 6.0 LS swap with stainless work headers with no mods. Just a little tweeking on passenger side frame rail. When you look at it it's impossible to see it.
Link to more pictures.
http://67-72chevytrucks.com/gallery/...y.php?cat=1979
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-20-2014, 04:47 PM   #4
Tennessee Bowtie
Stainless work? Is that the brand do u have a part umber or website. I'm not trying to brake the bank also.
Old 07-20-2014, 05:08 PM   #5
truckdude239
truckdude239's Avatar
I used trailblazer ss manifolds with the down.pipes that ca me withyour motor and they cleared perfect
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-20-2014, 05:18 PM   #6
trkfrk
trkfrk's Avatar
The Doug Thorley's seem to be very popular with the LS swaps. They fit really well and look nice.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 07-20-2014, 05:21 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Ls swap headers????
I will warn you they arn't cheap! Yes that's the name of them.
http://www.hawksthirdgenparts.com/pr...Collector.html
Old 07-20-2014, 07:46 PM   #8
RaceAGMC
RaceAGMC's Avatar
Another vote for Doug Thorley's, POL tubular motor mounts and adapter plates, slid right in with no clearance issues at all.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 07-20-2014, 08:48 PM   #9
Pro Performance
Pro Performance's Avatar
Hedman also makes LS swap headers specifically for the C10 trucks. We are a dealer, so let m know if we can help you out.
Pro Performance is offline   Reply With Quote
Old 07-20-2014, 09:08 PM   #10
Tennessee Bowtie
How much?
Old 07-20-2014, 10:06 PM   #11
69Rumbler
69Rumbler's Avatar
Yea I need a set for my truck to ^^ how much lol
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline   Reply With Quote
Old 07-20-2014, 10:59 PM   #12
Tennessee Bowtie
As of now I will be using early classic mounts and trans crossmember. My factory exhaust manifold r cracked at welds. However what I am looking for is something nice, fairly cheap that will get the job done without turning into a hack job.
Old 07-20-2014, 11:04 PM   #13
Tennessee Bowtie
Another member told me these were the best choice are far as cheap and effectiveness. Any input?
http://www.ebay.com/itm/like/301143029583
Old 07-20-2014, 11:10 PM   #14
Tennessee Bowtie
Also what about these?
Amazon.com: PaceSetter 72C2276 Long Tube Header... Amazon.com: PaceSetter 72C2276 Long Tube Header...
Old 07-20-2014, 11:21 PM   #15
Tennessee Bowtie
I don't really want to spend this much but are these easier or a better route?
Old 07-20-2014, 11:21 PM   #16
Tennessee Bowtie
Amazon.com: Hooker 2289-1HKR Super Comp. Ceramic... Amazon.com: Hooker 2289-1HKR Super Comp. Ceramic...
Old 07-21-2014, 01:14 PM   #17
Tennessee Bowtie
Bump
Old 07-21-2014, 04:31 PM   #18
Lees68GMC
Lees68GMC's Avatar
The main thing I don't like about long tube headers besides the cost is their only advantage in flow performance is seen above 6000 RPM typically and every one made the collectors hang down below the frame rails.
Having done many hot rods and my 2nd GMC truck I wanted the entire exhaust up inside the frame rails. New Camaro owners love installing long tube headers on their New car, so the LS3 OEM exhaust manifolds are every where used and Cheap. Mine came off a crate engine never used. The OEM 5.3 truck manifolds hit the frame rails on these old trucks, these 2013 Camaro LS3 manifolds tuck inside the frame rails, you use the stock Camaro head pipes cut-off in front of the cats, preserving the O2 sensor bungs. My exhaust is run where I want it, No clearance issues. The LS3 Camaro made in stock configuration 436 HP with these manifolds. I'm happy, just my two cents
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 07-21-2014, 04:39 PM   #19
Tennessee Bowtie
I think I'm going to try and find some. Thanks do u you happen to know where any are for cheap?
Old 07-21-2014, 04:43 PM   #20
boraxman
Keepin an eye out
boraxman's Avatar
Sanderson shortys - Getting the job done/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 07-21-2014, 04:46 PM   #21
boraxman
Keepin an eye out
boraxman's Avatar
Look on Corvette forum c6 parts section/
ZIP 91351
Old 07-21-2014, 11:37 PM   #22
Pro Performance
Here is a few options from Hedman.
Uncoated, Mid Length, 1.75" Primary: $375 shipped
Coated, Mid Length, 1.75" Primary: $665 shipped
Old 07-21-2014, 11:39 PM   #23
Pro Performance
Installed in a customers truck
Old 07-22-2014, 12:12 PM   #24
Lees68GMC
Lees68GMC's Avatar
Really nice work, especially for desert dwellers
Is that a radiator you guys sell? Stock mounts?
98 Chevy Blazer ZR2
Old 07-22-2014, 12:47 PM   #25
littlevictories
I used the pacesetter TBSS longtubes on my '66 lwb
stock sbc pedestals and $40 ebay adapters
needed to trim the frame 1/4" with a cutoff wheel
but otherwise I'm happy. they were like $250 from amazon
fyi, they exit tucked way up in the frame
had to use s-bends to go under the trans cross member (pre 75 dual exhaust style one)
littlevictories is offline   Reply With Quote
