07-21-2014, 10:50 AM | #1 |
66 VIN Help
I've been pouring over the board and the internet for the last week looking for an answer on this and have almost given up. When I got my truck, the PO signed over the title and I took it to DMV, retitled it, no problem. The problem is, my VIN looks nothing like any of the others I have seen. I also can't seem to find anything on the truck itself. The number on the title is "I1002PD13211A". Any advice?
07-21-2014, 10:59 AM | #2 |
Re: 66 VIN Help
any pics of the truck and the vin tag?
07-21-2014, 11:00 AM | #3 |
Re: 66 VIN Help
I haven't been able to find a vin tag. Is there anywhere that the number would be stamped?
07-21-2014, 11:05 AM | #4 |
Re: 66 VIN Help
Looks like a gmc vin id. GMC vin #'s were much different than chevy vin #'s. You should find a matching serial number on top of the frame rail inside the engine bay. Driver side over top of where the a-arm sits.
Edit: 7/22 No frame stamp on the GMC's I1002PD13211A I = Inline engine 10 = 1000 series 02 = 127" wheel base P = Pontiac plant' D = inlined engines for 66 gmcs 13211 = serial #.......they started at 10,0001 that year A = 6,000lbs gvw or less
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-22-2014 at 08:08 AM. |
07-21-2014, 11:48 AM | #5 |
Re: 66 VIN Help
Perfect! Thank you! I was starting to get a bit worried.
07-21-2014, 11:54 AM | #6 |
Re: 66 VIN Help
No worry....vin looks correct for your truck.
Good link for GMV VIN's : http://6066gmcguy.com/VinNumber.html
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-22-2014, 12:26 AM | #7 |
60-66 Nut
Re: 66 VIN Help
As far as I know the GMC frames are not stamped with the VIN. All the OP will have to go by in the tag in the door jamb. Hopefully it is present.
07-22-2014, 08:08 AM | #8 |
Re: 66 VIN Help
Sorry.....couldn't remember 100% if the GMC's were frame stamped
07-22-2014, 08:11 AM | #9 |
Re: 66 VIN Help
I agree with captain fab . Ive never seen or owned a GMC that had the vin number stamped on the frame. if the tag on the door jamb isn't there you more or less have a truck without a valid title.
07-22-2014, 08:55 AM | #10 |
Re: 66 VIN Help
Thanks all for the help! Unfortunately, there are no tags that I could find. I haven't gotten through all of the boxes of parts yet, so it could be laying in the bottom of a box, but it definitely isn't on the truck.
