07-21-2014, 02:21 PM | #1 |
Best riding rear suspension set up.
I have a 68 C10 with rear coil suspension. It has 5 inch drop springs from ccp and they are soft as butter. If someone sits on the tail gate it will almost bottom out! Whats a good spring for handling that has a little drop to it? The front just has 2 and 1/2 drop from the lowering spindles. Also it seems I need Rear Shock Relocator from no limit. I already have no limits panhard bar kit installed. Would it be better to use lowering blocks?
07-21-2014, 05:57 PM | #2 |
Re: Best riding rear suspension set up.
I also have the rear CPP 5" springs in mine. Same result as you....pretty spongy. I'm gonna watch this thread and see what comes outta it. I've too been wondering about a stiffer spring with same amount of drop.?!
07-21-2014, 07:25 PM | #3 |
Old member
Get yourself some load bags. They are in my signature. They work great and you can adjust them for the right ride. Yes the No limit shock kit is a great addition as well. I have both and my 71 drives great.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
07-21-2014, 08:25 PM | #4 |
I have no first hand experience with this yet but I've done a lot of reading on it since I'm putting trailing arms under my 78. I saw a lot of people recommending to get the first 1.5-2" of drop from a block to keep the spring as long as possible for a better ride. So if you wanted a 5" drop then a 2" block an a 3" drop spring should yeild a better ride.
Again just something I've seen recommended over an over on this forum.....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
07-21-2014, 11:45 PM | #5 |
I have those bags actually installed. I need like a 3-4 inch drop spring to have it where i want it.
07-25-2014, 08:06 PM | #6 |
What spring and block is recomened? Ive read allot of the same posts saying to static drop them that way, but never any specific parts info... ive also heard.that pb trailing arms have 3" drop built in, so would those.with a.2" spring be ideal?
67 small window swb 98 bagged s10 (orig owner) 99 z71 01 swb Last edited by Nola67; 07-25-2014 at 08:07 PM. Reason: info |
07-25-2014, 11:38 PM | #7 |
Yep I could use some part #s
07-26-2014, 12:06 AM | #8 |
motor exploder
You might also contacting GMC Paul's (board vendor) they do custom rear springs in a variety of rates. I have no idea what the spring rates are on the CPP springs, I tried to find out the spring rate of the 2" drop front springs I got from them and never got an answer, so I ordered my rear springs from GMC Paul's to make sure I got what I wanted.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
07-26-2014, 02:15 AM | #9 |
meowMEOWmeowMEOW
Trailing arm rear suspension, relocated adjustable coilovers, or a good shock and a 7" bag.
Honestly, on the trailing arm rear, a good shock and a halfway decent spring rides better than prob 90% of the leaf spring trucks here.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-26-2014, 08:29 AM | #10 |
Old member
I am one who doesn't like the rear blocks. If u do run them make sure the wheel is big enough so that the u bolts don't stick below the wheel. Blocks in my opinion are for a cheap lowering kit.
Getting a good spring is the key. The No limit shock relocator kit are some one elses kit is a must have. Having the shock perform as they are intended to do is key also.
07-26-2014, 08:28 PM | #11 |
Well I have the shock relocater kit coming in from no limit. Can my stock shocks be used? They are new. I will eventually put bilstein shocks on all 4 corners. I noticed my pan hard par was contacting the rear exhaust and would limit travel. That is now fixed.
07-27-2014, 02:36 PM | #12 |
My plan on the advice of a few people I've talked to is to go with ECE springs as they aren't near as spongy.
I already have the CPP 4 wheel disk conversion so I'd like to stick with their DS and other components. If you're willing to drop a few bucks on the ECE springs it may solve the sagging rear. |
07-27-2014, 11:12 PM | #13 |
Hi Vannatta20, my 68 c10 is equipped with 2 1/2" dropped spindles in front, and 4" ECE brand coils in the rear. I have hauled 1,000lbs many times doing home improvements projects and on rare occassions it bottoms out. The best changes i made in the rear for a better controlled ride were, shock relocaters, and installing a porterbuilt panhard bar. I have been using monroe sensa-trac shocks and can say they work pretty good. Before the changes with the 4" lower springs already installed the rear would bob up and down too much, but rides great now. Good luck, Brian Fuller
07-28-2014, 11:06 AM | #14 |
I think you're going to be surprised at how much of a difference the shock relocators make. Right now, your shocks are at such an angle that they aren't very effective. Standing the shocks back up to the right angle will make a big difference on ride and handling.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
07-31-2014, 10:09 PM | #15 |
I don't think your stock shocks will work, if I recall the stock shocks are shorter than the ones that No Limit uses. I'll try to get the # off of mine over the weekend which will allow you to cross reference.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
07-31-2014, 11:20 PM | #16 |
I hope I don't run into this; I have a cpp big slam kit with 2.5/4" drop on the way. Also ordered the shock relocators and and adjustable panhard bar.
08-01-2014, 09:12 AM | #17 |
Old member
I agree the stock shocks may not be long enough to work with the No limit kit. I bought all of it together. They move the shocks out ward and further back on the frame to make a much better ride and handling.
08-05-2014, 10:34 PM | #18 |
The no limit shock kit sure does lower the scrubb line. Must need a 17" rim of bigger to be safe
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-26-2015, 04:54 AM | #19 |
Good point! The no limit kit looks like it lowers the scrub line. I have also noticed i haven't seen any pictures of the no limit kit installed with a hitch kit. I am looking to install a shock re locator kit and a CPP hidden hitch kit. The CPP hitch kit runs up the side of the frame. Would it interfere where the no limit bracket mounts. Has anyone tried this combination?
01-26-2015, 10:23 AM | #20 | |
01-26-2015, 06:01 PM | #21 |
I was told via email to No Limit that a 15 inch wheel could be safely used. I have yet to purchase this kit. Anybody know of anybody who has ran a 15 inch wheel?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
02-07-2015, 07:19 PM | #22 | |
I guess it depends if you are using it as a truck to carry things or just want to rip around. I just want to rip around. Anyone got ideas about that.?
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
02-07-2015, 07:49 PM | #23 |
meowMEOWmeowMEOW
A softer spring will let the rear float a bit more, and prevent it from being bouncy over washboard roads and things like that...but it will also have a tendency to roll/lean more.
A stiffer combo will corner and handle flatter/better, but will feel harsher. This is most common with dropped trucks where the spring has to be stiff to carry the weight of the truck. Better shocks/adjustable shocks help and give you some more leeway with controlling the weight as well. Its usually a good idea to upgrade both systems at once, otherwise you may not be taking full advantage of either upgrade. I really like some of the variable rate springs for trucks, which allow a softer spring that stiffens at the bottom 1/3 to still offer an improved response.
02-09-2015, 01:37 PM | #24 | |
Does anybody make a variable rate spring for a 4" drop in the rear? |
03-22-2015, 01:18 PM | #25 |
ttt for variable springs
