Old 07-21-2014, 02:30 PM   #1
zigs74
drop spindles?
Ik this has been covered a lot but I would like a little more input between which size spindles & springs. I'm currently looking at Bell Tech 3" spindles & 1" springs with a coil cut for five" drop? Also what if I did 2.5 spindles 2" springs 4.5 drop? Would there be much of a difference in ride or rubbing? A 6" drop flip kit & plan on using the stock 15" rallies for quite some time. I like the way they look but maybe plan on putting 20's in the future. One last ?, What could I expect to pay for the labor? Thx evy1!
zigs74 is offline   Reply With Quote
Old 07-21-2014, 03:45 PM   #2
DREAMER1
DREAMER1's Avatar
Re: drop spindles?
If you're buying aftermarket springs, I don't recommend cutting them. They're made differently than factory springs. I cut one round off of my factory springs to give me roughly a 2" drop...then used 2.5 drop spindles. I had a 4.5" drop with 20" rims, I would rub when I hit big pot holes.
DREAMER1 is offline   Reply With Quote
Old 07-21-2014, 03:58 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: drop spindles?
Stock rallies and the drop that you want will undoubtedly give you some issue with rubbing of the lower control arm on the inner edge of the rim. You will have to go to a larger diameter of rim to clear the LCA.
Frank
Old 07-21-2014, 06:13 PM   #4
zigs74
Re: drop spindles?
Ok Dreamer good to know.
I've read somewhere that grinding of the LCA can be done but is that all that is needed?
Old 07-21-2014, 08:46 PM   #5
Sodell
Sodell's Avatar
Re: drop spindles?
You just need to use 7" rally's, they work great for the front...., does Bell tech not make a 2" drop spring? Or do you already have them?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 07-21-2014, 09:07 PM   #6
zigs74
Re: drop spindles?
They do Sodell. I'm just a slow learner. lol Thx.
Old 07-22-2014, 07:35 PM   #7
zigs74
Re: drop spindles?
K so, so far I found surprisingly everything I need from all in one store, "Western Chassis" 2.5 spindles, 2" springs and 6" flip kit all for $480.
Old 07-22-2014, 07:43 PM   #8
bdiamond
Re: drop spindles?
My blazer sat low in the back with a similar front drop to what you have planned.
bdiamond is offline   Reply With Quote
Old 07-22-2014, 07:54 PM   #9
school boy
school boy's Avatar
Re: drop spindles?
I thought 2.5 drop spindles would clear the 15x8 ralleys?
school boy is offline   Reply With Quote
Old 07-23-2014, 07:22 PM   #10
Sodell
Sodell's Avatar
Re: drop spindles?
Don't think they will....
Scott
Old 07-23-2014, 07:24 PM   #11
zigs74
Re: drop spindles?
From what I hear the 15x7 will.
Old 07-23-2014, 08:06 PM   #12
bbbc10
Diggin The SquareLife
Re: drop spindles?
dnt forget shocks also
bbbc10 is offline   Reply With Quote
Old 07-23-2014, 08:47 PM   #13
zigs74
Re: drop spindles?
I thought about shocks but the truck has 48k original mileage. Are you referring to drop shocks?
Also the package is more like $590. I forgot tax & shipping.
Old 07-23-2014, 09:42 PM   #14
mm1077
Active Member
mm1077's Avatar
Re: drop spindles?
I've got 3in drop spindles with 1 and 1/4 coils cut off the stock springs on my Blazer. There were no issues with the 15x7 stock rallies hitting. I'm not sure of the spindle brand since I bought them used. I have 4" western chassis drop leafs on the rear. I have 20s now w 245 45 20 in the front and there hasn't been any rubbing issues either.
mm1077 is offline   Reply With Quote
Old 07-24-2014, 01:46 AM   #15
bbbc10
Re: drop spindles?
yes im talking bout drop shocks...Im running belltech drop shocks on mine
Old 07-26-2014, 12:35 AM   #16
Sodell
Sodell's Avatar
Re: drop spindles?
the 15x7 will clear the front for sure. You can also run stock shocks with no problems, just going the two inches with the springs, the spindle does not affect the shocks.
You can also save some money by using 79 Toyota 2WD shocks for the rear...don't forget you will need to get an alignment once those springs are installed.
Scott
Old 07-26-2014, 09:07 AM   #17
blazer2007
Re: drop spindles?
I,m sure you will have to put a c-notch in also,my truck I didn,t but the blazer I did.It seems to sit lower as well, I had to run a taller tire to bring it up if I remember correctly.
blazer2007 is offline   Reply With Quote
Old 08-19-2014, 01:29 PM   #18
zigs74
Re: drop spindles?
So here it is. I'm lookin @ lift shackles to bring the rear up some. LOL. Right now the rear is totally bottomed out on the shocks so it may even fall a bit lower if I were to remove them for drop shocks. I have about an inch from the rear axle to frame. Bump stops are totally removed.
Old 08-19-2014, 01:58 PM   #19
bob_o
bob_o's Avatar
Re: drop spindles?
Hell yeah, looks dope.
1975 GMC Sierra - Electric Funeral
1962 Buick LeSabre - Mr. Krinkle
bob_o is offline   Reply With Quote
Old 08-19-2014, 02:01 PM   #20
zigs74
Re: drop spindles?
Haha, just rides like shhhhh. Although I'm very happy with the clearance with the steering. It doesn't even rub. They must be 15x7 ralleys.
Old 08-19-2014, 04:59 PM   #21
Rich84
Rich84's Avatar
Re: drop spindles?
Maybe you should be looking at some new leaf springs to bring it up a little and get a better ride. I think the condition of the springs is the main reason everybody gets different drops with the same components.
Rich84 is offline   Reply With Quote
Old 08-19-2014, 10:16 PM   #22
zigs74
Re: drop spindles?
That sounds like a fantastic idea Rich. I'll look into that.
