Old 07-21-2014, 10:39 PM   #226
racecougar
racecougar's Avatar
Re: Bringing the '65 back to life
Thanks guys! The best part was seeing Dad stare at it for awhile. This has already been a great build.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 09-20-2014, 09:23 AM   #227
racecougar
racecougar's Avatar
After taking time for a bunch of other projects, we got back to work on the '65 last weekend.
I DA'd the roof...
...while Dad blasted the engine crossmember.
Straightening a lifetime of dents out of the roof panel required judicious use of the stud gun and my "go-to" body hammer. Once it was all worked out, we put it into primer.
I also spent a chunk of time taking care of little details that no one will ever notice, like blending out this little scallop on the engine crossmember. The crossmember and the drip rail around the roof panel are now far smoother, straighter, and more uniform than when they left the factory.
I sealed up the roof seam yesterday afternoon. It should see another coat of primer at some point this weekend.
Old 09-20-2014, 09:36 AM   #228
Ta2Don
Ta2Don's Avatar
Looking Great...
Glad to see ya back after it...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 09-20-2014, 05:14 PM   #229
racecougar
racecougar's Avatar
Thanks! It's nice to be back on it.
I sprayed the second coat of primer this afternoon. Time to let it dry, then block it out.
Old 09-20-2014, 06:22 PM   #230
bj383ss
bj383ss's Avatar
Looking good man. I can't get any of your pictures to pull up maybe its my computer. Question for you did you use the 2 part 3M self leveling seam sealer for the roof that goes in the dual caulk gun? And if so did one tube do the whole top? I feel like there isn't enough in the tube to make it around, but I don't want to buy a second one at$35 if I don't need it.
I'm getting ready to do my roof in a couple of weeks on my vacation.
Bret
Never mind got your pictures to work.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 09-21-2014, 03:43 AM   #231
racecougar
racecougar's Avatar
Bret
No, I used the brushable seam sealer that I posted earlier: http://67-72chevytrucks.com/vboard/s...&postcount=152
I masked off the drip rail and worked one small section at a time. I'd brush in the seam sealer, then smooth it out with a gloved finger. It worked out quite well. I used toothpicks to keep the four drain holes open until the seam seal cured.
Old 09-21-2014, 10:31 AM   #232
Bomp
Bomp's Avatar
Roof is looking great. Noted the tooth pick idea for when it comes time to do mine.
Bomp is offline   Reply With Quote
Old 09-28-2014, 04:37 PM   #233
racecougar
racecougar's Avatar
Thanks!
We're getting somewhere with the roof. We spent the day blocking it out, then shot the third coat of primer. We'll see if it needs another coat after it gets blocked out this week.
Old 09-29-2014, 08:53 PM   #234
racecougar
racecougar's Avatar
Dad went to check out a pair of '64-66 doors from a Craigslist ad this morning. As it turns out, the seller was one of my high school teachers, and he ended up giving us one heck of a deal. The main focus was the passenger door. While it will need some work, its condition is leaps and bounds above that of the original passenger side door. As far as the driver's side is concerned, it's a toss up between this one and the other good door Dad purchased a while back.
Old 09-30-2014, 06:44 PM   #235
racecougar
racecougar's Avatar
Dad blocked the roof today, then I shot what should be the last coat of primer. It'll hopefully turn gloss white this weekend.
Old 10-04-2014, 10:19 PM   #236
racecougar
racecougar's Avatar
It was a bit chilly this morning. Rather than heating the shop to be able to paint, I started sanding the back of the cab. Good lord, that's a dusty job!
Old 10-05-2014, 03:13 PM   #237
racecougar
racecougar's Avatar
The control arm shaft kits arrived from Rock Auto yesterday.
I had planned to set the LCA shafts up in the mill to relocate the locating bore a bit further aft to increase the positive caster angle, however the bores on the aftermarket shafts were already 1/4" back from stock. Job done! Dad blasted the shafts and I put them into primer.
Rather than stick with the stock LCA shaft U-bolts, I ordered the much beefier '73-'90 version. They fit perfectly after opening up the original holes in the engine crossmember.
The roof needed another pass with primer in a few areas.
Old 10-05-2014, 06:33 PM   #238
bj383ss
bj383ss's Avatar
Man I was hoping to see some paint on the roof. Now you got me wondering if my new control arm shafts had the notch moved back.
I second your comment on the back of the cab. Still working on that right now. I have a huge dent right below my window I am trying to fix. I really don't want to put a bunch of bondo on it but I really don't have a choice. I almost have the bodywork on the roof done. When I finish that will put it in primer and then I am going to paint the inside.
Old 10-05-2014, 07:21 PM   #239
racecougar
racecougar's Avatar
Me too, but there were a couple little dips that were still showing guide coat. Hopefully it'll see paint next weekend. The back of this cab is riddled with dents, including a few that are pretty large. It is going to take a lot of pulling and bumping to get it straight.
Old 10-05-2014, 07:44 PM   #240
TJ's Chevy
TJ's Chevy's Avatar
Roof came out nice!
Old 10-11-2014, 07:17 PM   #241
racecougar
racecougar's Avatar
Thanks!
Dad shot the crossmember and control arms gloss black during the week.
We spent the morning cleaning up the back room of the shop and organizing parts storage before getting started on the back wall of the cab. We rotated the cab to place it between two of the posts in the shop, as there was one dent in particular that required a decent pull. I welded an eyebolt to the lowest point of the dent, then pulled while bumping effectively off-dolly to shrink the metal back into shape.
The same method was used on the smaller dimples and creases, only with the use of the stud gun rather than the eyebolt.
It still needs quite a bit of work, but it's coming along.
Old 10-12-2014, 11:04 AM   #242
Bomp
Bomp's Avatar
Nice seeing the progress. Looking good
Old 10-12-2014, 06:44 PM   #243
racecougar
racecougar's Avatar
Thanks Bomp!
We spent the morning bumping to get it all as straight as possible before Dad started spreading filler and boarding it. We'll see how it looks next weekend.
Old 10-19-2014, 03:59 PM   #244
racecougar
racecougar's Avatar
Dad finished up the body work on the back of the cab during the week...
...and I laid down two coats of primer today.
Old 10-25-2014, 04:33 PM   #245
racecougar
racecougar's Avatar
After the final blocking, the first coat of gloss white made its way onto the roof today.
Old 10-25-2014, 10:14 PM   #246
Ta2Don
Ta2Don's Avatar
Lookin Sweet!
DON
Proverbs 27:17
Old 10-25-2014, 11:48 PM   #247
dantimdad
dantimdad's Avatar
I cannot wait until I am to that point!
Great job!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 10-26-2014, 04:10 PM   #248
racecougar
racecougar's Avatar
Thanks guys! Each coat must pass the most rigorous inspection process...Dad's approval.
Old 11-15-2014, 03:27 PM   #249
racecougar
racecougar's Avatar
While I took a couple weeks off to tend to other matters...
Dad installed additional lighting over the main bay, moved the cab back over to the main bay, cleaned/organized the shop, and blocked out the roof for the final coat, which I shot this morning.
Old 11-16-2014, 06:15 PM   #250
racecougar
racecougar's Avatar
It needs to be cut and rubbed of course, but I'm happy with how the roof turned out.
