#51 |
A320 Pilot/USAF Retired
Re: 59 fleetside longbed build
Nice build!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#52 |
The bodywork on the cab, fenders and hood is pretty much done and we are fitting all the pieces now.
#53 |
#54 |
We also cut out the center section of the dash and replaced it with a flat panel. We are probably going to put a double din in that spot.
#55 |
Looking real nice.
Kim |
#56 |
Nice build, love the old impala steering wheel.
58 Fleetside 71 Cheyenne |
#57 |
looking good
![]() if you don't need your ashtray... cut it out and all the slide behind it gives you a lot more room in that area to run wires or ac ducts i shaved my dash but did not gut the slide and wished i had i have pulled a lot of skin off on that slide thingy ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#58 |
The cab and and all the other body parts are back at the shop for paint. We stripped down the chassis and it's getting powdercoated now.
#59 |
Nice.
Kim |
#60 |
We got the chassis back from powdercoat and now we're putting it back together.
#61 |
The cab is done getting painted. It is lime rock green and pearl white.
#62 |
Looking real nice.
Kim |
#63 |
I like the green it will look sweet together
1958 Chevy Apache Stepside 1955 BBW Fleetside |
#64 |
Very nice!
#65 |
The bed is done getting painted and the bed wood is all stained. We also polished out the rails for the bed.
#66 |
That looks great.
Kim |
#67 |
that looks sweet ![]()
#68 |
The cab is done and we're putting everything back together.
#69 |
It sure is looking nice.
Kim |
#70 |
Very, very nice indeed!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#71 |
Your truck is come a long way in a "relatively" short time (at least how I measure time when on a build!). Thanks for posting the pictures of the progress. I do have a question, where did you get your dropout battery box - that is one of the next items for me to address on my build.
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
#72 | |
#73 |
All of the glass is in, despite some modifications to the back window. We also mounted the steering column, shifter and handbrake.
#74 |
We mounted the core support and radiator. There is one inner fender in right now to check the clearance on the power steering hoses and trans lines that we mounted.
#75 |
We started the wiring for the engine, trans and the lights up front. We also test fit the intake.
