Old 07-22-2014, 09:35 PM   #1
Johns66
66 automatic column pictures needed
I need some pictures of the bottom of a tube assembly of a factory automatic column (power-glide or turbo-hydromatic) where the shift lever butts up to the clamping ring. A couple side shots and a front shot would be most helpful.
What I am trying to see is if there is supposed to be a space in between the lever and the clamping ring and if so what that spacing is.
In this picture there is some space between the clamping ring and the base of the shift lever.
I have checked my assembly manual and shop manuals and cannot find anything on this.
Thanks,
John
Johns66 is offline   Reply With Quote
Old 07-22-2014, 10:09 PM   #2
pimpston65
pimpston65's Avatar
Re: 66 automatic column pictures needed
as long as nothing was removed and the unit selects in and out of gear should be fine... looks like it should btw
pimpston65 is offline   Reply With Quote
Old 07-22-2014, 10:21 PM   #3
Johns66
That I can tell nothing had been removed. I disassembled because the end of the tube was all rusted up at the detent and lever. The spring compresses by hand now so I will start reassembly.
Thanks for looking.
Old 07-22-2014, 10:25 PM   #4
pimpston65
pimpston65's Avatar
Thanks for looking.
i will send a pic of mine in the am, mine works fine. nothing moved so it should be a good reference.
Old 07-23-2014, 10:27 PM   #5
pimpston65
pimpston65's Avatar
this is mine right before i rebuilt it, worked perfect...
Old 07-23-2014, 10:28 PM   #6
pimpston65
pimpston65's Avatar
look like your spring needs to be let down til it touches
Old 07-27-2014, 06:07 PM   #7
Johns66
Ok great thanks for the picture, got the lever realigned.
Did you have to press the lower bearing race out in the bottom of your column to put in a new one?
Old 07-27-2014, 06:26 PM   #8
pimpston65
pimpston65's Avatar
when i took it all apart the only thing that held was the race the bearing was shot so it was able to be knocked out with little effort
