Old 07-23-2014, 09:36 PM   #26
Nin92
Nin92's Avatar
Re: Project Tow Mater
So since having her back at the shop it's just been a lot of little things like trim, rubber seals and glass. Most of the trim is done it's just down to putting the windows back in and rebuilding the vent windows which is the current task at hand.
Nin92 is offline   Reply With Quote
Old 07-24-2014, 07:21 PM   #27
Nin92
Nin92's Avatar
Finally getting started on the vent windows today. Figured Id do one at a time.
Old 07-24-2014, 09:34 PM   #28
Nin92
Nin92's Avatar
Got one of them done minus the hinge rivet and latch. Considering just doing a stainless nut and bolt instead. Wasn't nearly as bad as I thought it would be but using tire mounting lubricant was a big help! Got started on the next one and as soon as I went to tap out the roll pin in the vent latch it exploded into pieces... Thank god I have an extra that I can use! Going to get the other side finished tomorrow!
Old 07-25-2014, 01:09 AM   #29
whitels1
whitels1's Avatar
Truck is looking great, nice job!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 07-25-2014, 03:24 PM   #30
Nin92
Nin92's Avatar
Thanks I really appreciate it!
Old 07-25-2014, 06:27 PM   #31
JacobSchni
JacobSchni's Avatar
are you gonna put the boggers back on the new wheels?
JacobSchni is offline   Reply With Quote
Old 07-26-2014, 08:58 AM   #32
Wrecked1982
Wrecked1982's Avatar
very nice work!! always wanted to do the old style front end swap. I would like to see how you patched the old Hood hinges hole
Wrecked1982 is offline   Reply With Quote
Old 07-26-2014, 02:44 PM   #33
Nin92
Nin92's Avatar
I would of if they weren't sized for 15" wheels. Once I did the 1-ton swap I couldn't fit 15" wheels over the front calipers. The current wheels are 20" and I'm looking at getting a set of 35x12.5-20 MT MTZs here shortly. The bias ply boggers were not too street friendly either haha.
Thanks! The front end swap bolted right in. Just make sure to use a OEM core support as the aftermarket ones are junk, do not fit up at all and a huge waste of time and money. I actually left them just incase I ever wanted to go back to the 81-87 front end but I may patch them when I do the Cummins swap and shave the firewall.
Old 07-26-2014, 04:23 PM   #34
JacobSchni
JacobSchni's Avatar
U selling the tires by any chance?
Old 07-26-2014, 06:35 PM   #35
y5mgisi
Second Chance Program
y5mgisi's Avatar
I would kill for you to get a different set of wheels for it, but other than that, i really like the truck!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 07-27-2014, 01:26 AM   #36
Nin92
Nin92's Avatar
Already had them sold right after I did the swap! Stuff doesn't sit around long with me haha
Thanks! And I know I know. I had them laying around and they fitted perfectly after the 1-ton swap. Plan on getting wheels when I buy new tires soon; something with less material on the spokes and more spokes.
