Old 07-27-2014, 04:56 PM   #76
step65
Re: My 65 step build and first chevy
I used the measurement as a reference to the rolled edge of bottom. With the bracket behind installed right it falls right into place.
step65 is offline   Reply With Quote
Old 07-27-2014, 05:01 PM   #77
step65
This door patch was the hardest so far. I used the wood trick I saw on a show to make the inner door piece. As you can see it was pretty much gone. This whole patch took a full day for me. Still got the other door to do.
Old 07-27-2014, 05:03 PM   #78
step65
A little tweaking here and there but I think it came out pretty good for the beginner I am
Old 07-27-2014, 05:57 PM   #79
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Awesome work!!!
Keep pluggin away at it!!!
Modges'66 is offline   Reply With Quote
Old 07-27-2014, 08:18 PM   #80
Bigru
Bigru's Avatar
Nice!
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 08-18-2014, 05:01 PM   #81
step65
Got the other door done over the weekend. Going to line up front fenders and make sure gap is good and they line up right. Then get the cab ready to pull
Old 08-19-2014, 07:38 PM   #82
Bomp
Bomp's Avatar
Nice looking project.
Bomp is offline   Reply With Quote
Old 08-19-2014, 08:10 PM   #83
K-Ray
Lookin good!
K-Ray is offline   Reply With Quote
Old 08-20-2014, 10:21 AM   #84
step65
Thanks guys for the support. I am hoping the media blast on cab goes well and no more surprises. Still have the dash to patch where radio opening was cut.
Old 09-07-2014, 03:45 PM   #85
step65
I worked on the inner fenders grill support and radiator support this weekend. I used the 3M undercoating and got the inner fenders and rad support painted. I will paint the grill support when painting front fenders and stuff. Came out pretty good.
Old 09-07-2014, 03:52 PM   #86
step65
Got done in time to go for a quick ride with my other toy.
Old 10-17-2014, 08:19 PM   #87
step65
Got the cab off last weekend
Old 10-17-2014, 08:21 PM   #88
step65
Took it to get media blast today. He used crushed glass came out real nice.
Old 10-17-2014, 08:23 PM   #89
step65
More pics
Old 10-17-2014, 08:26 PM   #90
step65
Things we found under the bondo door mirror mount inside of door to help stop bondo from falling in. One inch hole in roof for old CB antenna. One hole passenger side for another cb antenna. All kinds of holes inside cab. Tomorrow is hole filling day.
Old 10-17-2014, 08:28 PM   #91
step65
Got to say all in all this cab is pretty solid not much rust anywhere.
Old 11-19-2014, 10:16 PM   #92
step65
Have been busy lately and wanted to update but just now got the time. I have got the floor of cab all finished up here. I welded up the extra holes then sealer primed. The next day hit with red scotch-brite and undercoated using the 3M.
Old 11-19-2014, 10:17 PM   #93
step65
sealer prime
Old 11-19-2014, 10:18 PM   #94
step65
Under coating
Old 11-19-2014, 10:22 PM   #95
step65
Then I got started on the dash. You can see where it was bent in up top pretty good. Also the radio area had been cut larger. I decided to patch. I got it at Brothers really cool store front they have. I mentioned the site and they gave me a discount which was awesome.
Old 11-19-2014, 10:30 PM   #96
step65
I cut the dash leaving both brackets on one was the dash instruments and the other side was for glove box. The patch has the instrument bracket but not the glove box. Once I fitted the patch and lined up the instrument side together I tacked in. Once I was sure the holes lined up to the instrument panel I cot the old bracket off from behind the dash. This was the hardest patch I did on whole truck. After I tacked it in I also checked the glove box fitment had quite a time getting the lower left gap set on glove box.
Old 11-19-2014, 10:33 PM   #97
step65
Then I started getting the major areas of body work done so I could prime for block sanding.
Old 11-19-2014, 10:35 PM   #98
step65
Here it is primed ready for block sanding. Also got the hood and front fenders primed for block sanding as well.
Old 11-19-2014, 10:42 PM   #99
step65
I got the roof all blocked in now and ready for sealer primer. I wanted to do the seam seal before the sealer primer. It came out pretty good. I used this brand after I saw it on a video and how easy it was to use and could use standard caulking gun. I have it sanded now and ready for prime with rest of roof. I also drilled holes where it drains. I had to tape them underneath to stop it from flowing out.
Old 11-19-2014, 10:44 PM   #100
step65
Here are the front fenders and cowl blocked and ready for sealer primer
