Old 07-27-2014, 11:06 PM   #1
weider1717
Need some help with custom 2" zero rates
Hey guys I have a truck that I want to keep as factory as possible and run 33x12.50's with a decent amount of room.
My thoughts is 2" zero rates all around well no major company makes them but I found a place JKW offroad that will make them custom for me.
Their website mentions they can mill 6" degrees etc into them.
my question is what degree should I ask for to keep angles correct? and do all four front and rear need this degree cut into them?
thanks!
weider1717 is offline   Reply With Quote
Old 07-28-2014, 10:47 PM   #2
weider1717
Re: Need some help with custom 2" zero rates
figured this would be an easy one with you guys.
Old 07-28-2014, 10:52 PM   #3
79Betty
79Betty's Avatar
Blocks are illegal in the front of a truck driven on the street... As far as the back,.. No clue... Just be careful.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-28-2014, 11:10 PM   #4
weider1717
research zero rate / ez inch leaf springs these are not blocks.
Old 07-29-2014, 07:37 AM   #5
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Actually they are blocks, the center pin just goes through them. Still a very bad idea for the front. They give the front axle too much lateral leverage on the front springs. Some 2 inch soft ride springs would be a much better plan. As for the rear, just talk to Steven at JKW, he is very knowledgeable and can probably help with a recommendation. Personally, with just 2 inches you probably won't need any adjustment.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 07-29-2014, 05:35 PM   #6
Ski-me
Ski-me's Avatar
Off Road Design is a good source. These are 1" though.....
Bolts into spring pack so it's considered a short, thick spring.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
I'd try these and see what kind of tire clearance you get. I had 33's at stock height with minimal rubbing. I have a 2.5" lift with 35's but may go back down to 33's if I can find the correct rims....
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 08-18-2014, 09:41 PM   #7
weider1717
anyone else running 2" zero rates? any suggestions? good idea or no
