Old 07-28-2014, 11:48 AM   #1
biohazardbill
LS Swap, 71 GMC
Picked up this little guy not to long ago
Plan on doing an LS swap.
What all is needed to make this as seamless as possible? Currently there is a 250 I6.
I plan on using 6.0 woth truck accessories, 4l80 trans and boyd tank for the rear. Debating on truck vs ls6 intake.
So what will be needed as far as conversion mounts, fuel lines etc?
Thanks in advance.
biohazardbill is offline   Reply With Quote
Old 07-28-2014, 12:33 PM   #2
Lees68GMC
Lees68GMC's Avatar
Re: LS Swap, 71 GMC
Love my LSX GMC
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 07-28-2014, 12:44 PM   #3
biohazardbill
Re: LS Swap, 71 GMC
What mounts etc did you use?
Old 07-28-2014, 12:56 PM   #4
Lees68GMC
Lees68GMC's Avatar
Re: LS Swap, 71 GMC
The Hooker header mounts from Speedway about $79.00. Don't be confused they are available in several set back dimensions, I used the Stock location ones and they worked great, either way you have to deal with tranny cross member location and have a correct drive-shaft built. Nice Truck by the way. To use an LS6 intake you sacrifice bottom end torque and move torque and HP higher up the RPM range. Not a particularly good application in a truck unless you expect to be up around 5500 RPMs a lot, does Look better though.
98 Chevy Blazer ZR2
Old 07-28-2014, 01:29 PM   #5
Matt Cramer
Re: LS Swap, 71 GMC
For conversion mounts, you can fab up a set yourself using dimensions given in the LS swap forum, or there's a ton of bolt on options as well. I cut a set out of 1/4" steel stock myself - see my build thread for details.
Most factory truck LS manifolds have a few frame clearance issues. If you want manifolds, Trailblazer SS or 2010 and later Camaro manifolds have good clearance. There's also a couple headers.
For radiator hoses, I used a set intended for a 2005 Silverado. Had to trim a little off the lower hose, and put dish soap on the ends to get them to slide over the (somewhat larger) fittings on my stock '72 radiator.
I just used a tubing bender and made my own fuel lines.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 07-28-2014, 02:09 PM   #6
Lees68GMC
Lees68GMC's Avatar
Re: LS Swap, 71 GMC
Yup he's right the truck manifolds hit the frame, I used 2014 Camaro LS3 manifolds because Camaro guys put headers on all the time and the manifolds are available cheap, they fit well and made 436 HP in the stock Camaro SS.
98 Chevy Blazer ZR2
Old 07-28-2014, 02:47 PM   #7
boraxman
Keepin an eye out
boraxman's Avatar
Re: LS Swap, 71 GMC
Hey Lees, where is your air intake pulling air from? Did you cut into the rad support? Where did you get that intake?
Im looking for something better, im getting high IAT as my cone sits between the engine and radiator/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 07-28-2014, 08:51 PM   #8
brushbuggy
brushbuggy's Avatar
Re: LS Swap, 71 GMC
i agree with Lee, love my 68 chevy with a 03 5.3 .I did mine and helped Lee with his. I used a aftermarket air intake from a 03 truck ,sorry no pic
brushbuggy is offline   Reply With Quote
Old 07-28-2014, 08:54 PM   #9
Lees68GMC
Lees68GMC's Avatar
Re: LS Swap, 71 GMC
Your Truck looks great Tim! Actually Tim did mine and I helped
98 Chevy Blazer ZR2
Old 07-28-2014, 08:59 PM   #10
Lees68GMC
Lees68GMC's Avatar
Re: LS Swap, 71 GMC
The intake is just the production K&N for a 2005 Suburban and that's the stock enclosure around the filter on mine, Problem is the 2005 Suburban OEM has Electric fan and we used a Mechanical fan, more efficient but bigger diameter rubbed the underside of the plastic intake tube. We heated the under side and pushed a "dent" in it to clear the fan. The LSX is just an e-bay stick on where we sanded the K&N logo off.
Heres a picture of Tims intake
98 Chevy Blazer ZR2
Old 07-28-2014, 09:14 PM   #11
brushbuggy
brushbuggy's Avatar
Re: LS Swap, 71 GMC
Thanks Lee
