#26 |
Moderator
![]() Join Date: Jul 2006
Re: "Black Betty" 1995 GMC Reg. Cab Sport Side
Oooh, almost forgot! I have been half-heartedly looking for a 88-94 gray seat in good condition because the 95 seat has me a little cramped. At 6-3/290 I need all the room I can get and the earlier seats help. Well this little gem popped up on Craigslist today and came home with me. I haven't seen one this nice in awhile.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#27 | |
"Oh well, it's a driver."
Wow, that seat looks awesome. Can't wait to see this thing on the ground.
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
#28 |
![]() Join Date: Dec 2013
Just curious what year seat do I look for that doesn't have the headrests,or do all years have them?
#29 |
Moderator
I think headrests started in '91.
#30 |
Clean looking seats!.
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
#31 |
That's a really clean 95. I could see it with blacked out front and rear bumpers, and doing the chrome grille bezel in black as well, all while retaining the factory trim. That would be one murdered out sleeper. Especially with a LS motor like you mentioned.
"And when he gets to Heaven, to St. Peter He will tell, "One more Grunt reporting Sir! I've served my time in Hell.""
RIP SGT. David L. Herrera. KIA Jan 26th, 2008. Baghdad Iraq. D Co. 2/506th INF, 101st Airborne Div |
#32 |
Moderator
#33 |
Lookin Good bro
1999 OBS Gmc Sierra ECSB Classic 1500 2wd-The Show truck (Black/Greystone metallic 2 tone) 1999 OBS GMC Yukon 4dr 2wd-Daily Driver/Toy (White) 1990 OBS GMC Sierra ST RCSS 2wd-100% Factory Original (Crimson Red/Metallic Silver 2 tone) 1997 OBS Chevrolet Silverado ECSB 2wd-Pops Daily/Tow Pig (White) |
#34 |
Moderator
Thanks man!
It's sad how long it takes me to do stuff in my own shop. I haven't driven it yet because I'm still messing around with small stuff. I have to notch the bed supports and re-install the bed, trim the LCA's (again), knock-out the camber adjustments on the upper control arms and of course finish the alignment. Here is a better photo.
#35 |
Man, it sure does look good!
#36 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Very cool.
#37 |
Moderator
Thanks guys!
I finished the bed re-install. I removed some plates that are on the bottom of the bed supports, which sit on top of the frame rails by cutting the spot welds. Then I cut out 3/8" from the bed support and tack-welded the plates back in, higher to clear the notch. I then moved the bracket that held the rear brake line tee and vent hose so it wouldn't hit the bed. Since the stock shocks were bottomed out sitting still I put new shocks on the rear, Monroe 32186. They are $20/each and have the perfect load, stroke and factory upper/lower mounts. So now everything clears and nothing bottoms out. I took it for a spin even without the alignment and it rides better than factory stock.
#38 |
Moderator
Alignment is done! Had to cut the front bumpstops for clearance but the lower arms are parallel to the ground and once the knock-outs on the upper arms were gone there was plenty of camber adjustment left. Kind of a pain though.
#39 |
Nice truck. Some trim rings on the wheels would look great I think if you're keeping the factory side molding.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#40 |
Trims rings with the chrome center caps would look pretty good; give some visual separation. Either way, this truck is a looker. Can't wait to see how it will turn out with a motor swap.
#41 |
Moderator
To me the trim rings don't fit the look I am going for which is a "sleeper, factory-stock, copo, shop truck" or whatever term describes the small hub cap on steel wheels flavor. I do like the trim rings on factory 88-98 rally wheels (which these are) but only in the stock argent color. But I'm just playing around so nothing is permanent : )
Ideally I'd like some 18" torque thrusts with machined lip/gray center, muscle car style.
#42 |
Moderator
Ignore the excessive wheel weights, here is a better side shot:
#43 |
Looks good, I'm debating if I wanna trade my rallys for a set of the steelies like that!
#44 |
GM Parts Guy
The look with the wheels is killer! I have the same style on my truck and always get compliments on them. I like to call them my poverty rims lol
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
#45 |
I'm quite jealous of your truck. If my 90 wasn't 4x4 id lower it, but then again I've debated lowing it anyways.
#46 |
Moderator
Switched the back glass to solid, getting tinted monday.
#47 |
Moderator
20% tint all the way around with a strip on the front. Much better!
I'm waiting for two things before the next phase begins. One is for me to finish another project so I have an open bay and the other is for the salvage yard to get a lower mileage 5.3L pullout.
#48 |
Moderator
Waiting on a heart transplant...
#49 |
wanna swap mine too? thats a beautiful truck!
2011 Silverado ECSB LT 2000 Silverado RCSB 2WD super bad habit of not owning a vehicle for a long time
#50 |
Rollin' Old Skool
Really like what you've done so far, & that was a great truck to start with! It's kinda the look I'm going for with my Tahoe. I plan to run Wheel Vintiques 15" steel smoothies, & I'll likely go black as well (except with trim ring). I saw your pic in the '88-98 dropped trucks thread, & I had asked about tires size. Glad I found your build thread though, because you cleared up that question here. I'm also leaning towards a set of Cooper tires for mine, but I'd like to do a staggered setup.
Keep up the nice work!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
