#101 |
Re: New Project: 1974 2WD Shortbed
I really like your truck. It will be nice when you get it all together. Keep working on it, it will be worth it when you get it done. Thanks for the update. Your sound system will be amazing when you get it together too.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
#102 |
Hey thanks. This board is really important with regards to keeping me motivated. Looking at other peoples projects that are similar in concept to what I want to do.....really helps me keep pushing on during the times when I loose interest. I have been working more than ever this summer on it. I just have been really bad at posting progress. I am going to try to get some more pics on a regular basis. Paint is on the horizon, and it is going to be fun. Fixing rusty metal is not the most exciting thing. But custom paint, gets peoples attention.
#103 |
#104 |
#105 | |
Why the different diameter choice?
#106 |
+1 on the difference in wheel diameter. 20s all around really is not that much more expensive, plus, if you plan to drive a lot, you'd be able to rotate the tires which can mean longer life for the tires.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
#107 |
17's with 20's.........The idea was that I was trying to get a staggered look. You guys could be right, I am not sure until I get them on the truck. The only catch is that I haven't lowered the truck yet, so I won't know for sure what it will/would look like with the 17/20 combination. Does anyone have pictures of a truck with a 17/20 combination?????? I am planning on the basic 4 1/2 front, 6 rear drop with spindles/cut springs in front and flip axle in the rear. No bags. If you guys are right and I don't like it, I will use the 20 x 8 1/2's in the front and put 20 x 10's on the rear. It will be next summer before I am ready to bolt the wheels and tires on for good anyway.....LOL
#108 | |
If you're dead set on a staggered combo, I'd suggest 19's/20's (but 19's are limited & therefore pricy vs just 20's).
#109 |
ok...I will think about this some more, as have not yet purchased the wheels. I do have the tires I was going to use. (not new, just used because I am still in the mock up stage)
I might try to pull the truck out this afternoon and set the tires I have in place and take a picture and post.....that will help me decide.... |
#110 |
#111 | |
#112 |
I went ahead and got the 17/20's on Saturday. I got the tires mounted up today. I am going out to the shop to put them on right now. I will get some pics soon.......
#113 |
#114 |
#115 |
#116 |
I just went through this from the beginning and you have given me so much more incentive to get my 86 shorty build going. I am lucky after seeing what you started with so i definitely cant complain anymore about the body work I need to do.
![]() Keep up the good work, I will be following this build to see where it goes.
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver. 86 Short box just starting the build. 86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come! 98 Cheyenne Ext cab short box 2wd. Driver and maybe future project. |
#117 |
Thanks. Yes, this truck was rough when I started. But I just wanted something to play with. Now I want to get to paint to see what I can do.
#118 |
Update pics. Working on mounting the fuel cell in the bed and making an access door. My favorite part is the push button latch I found from speedway motors. It works really nice. It is polished aluminum. It is going to be a nice touch when it is done and in paint. Springs pop the door up to open. I made the hinges from scratch.
#119 |
#120 |
#121 |
My hats off to you, I would have never started on a truck in that condition, you never batted an eye. Congrats on your work/progress
#122 |
Thanks. It is starting to all come together now. I am going to fix the doors next. Should be starting them in about 1 more week. This week I am going to finish grinding all the welds on the bed cover and get some etching primer on that area.
#123 |
Great Job Man! Truck is coming along great! Cant wait to see it finished!
1982 Chevy K20 350 Small Block 700r4 Trans 3/4 Ton Axles 35" BF Goodrich |
#124 |
Thanks. Almost done grinding the top of the bed welds this morning. A few days away from etching primer on top of the bed. This will only be the second time I have used etching primer before. So if I understand correctly, I should always be putting a coat of etching primer on my bare metal before using any plastic filler??? (Question for anyone out there with more experience than I) I am using the Eastwood etching primer.
#125 |
I finished the fab work on top of the bed, and got it covered with etching primmer. Will work on the filler and primmer work later. Moving on to the doors this weekend.
