07-29-2014, 12:16 PM | #1 |
Transmission hump
I got a question about transmission humps. what type of trucks used the tall humps was it just manual transmission and 4x4s. where they ever used on a 2wd big block auto.
Thanks |
07-29-2014, 01:16 PM | #2 |
Florida Edition
Re: Transmission hump
I believe the bolt-in high humps were 4x4 and big block only.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
07-29-2014, 11:23 PM | #3 |
Roadtrip!
4x4 or 4 speed or big block with auto trans trucks got them.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
07-30-2014, 12:19 AM | #4 |
Thanks for the help my 72 stepside is missing the hump and I was curious if it was correct for a big block auto
07-30-2014, 06:57 AM | #5 |
Only the 3 speeds had the small hump.
07-30-2014, 07:37 AM | #6 |
67-72 parts collector,…
And TH-350 and Powerglide automatic trucks.
07-30-2014, 10:55 AM | #7 |
If your truck is missing the hump and the high hump is the only one that bolts in wouldn't that narrow the field? My 68 GMC is a high hump it was 396 T400 it also is/was a 3/4 ton. I prefer the high hump as for the look inside as compared to the low one that is one reason when my 70 3oot is changed to the T-5 I am doing it back with a high hump as well. Jim
07-30-2014, 11:10 AM | #8 |
Thanks I didn't realize the high hump was the only one that bolts in
07-30-2014, 11:16 AM | #9 |
07-31-2014, 08:01 AM | #10 |
I didn't realize that the th350, th400 and the powerglide had low tranny humps well.
07-31-2014, 02:14 PM | #11 |
Scored a '72 Custom 20 with a rotted cab (I think I can lift the roof section off by hand!), but a nice high hump section. This will go into the '70 C10 T5/TPI set-up rather nicely.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
