Old 08-02-2014, 01:12 PM   #1
briank
restoration specs
Has anybody documented or is there a book (highly doubt the book) a 69-72 k5 blazer restoration regarding original finishes , fasteners etc??? I like originality and when I restore ky 72 I would like it to be as original. Thanks for any information
briank is offline   Reply With Quote
Old 08-02-2014, 01:18 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: restoration specs
There is the factory assembly manual available, although it doesn't list every detail.
1967-1972 Chevy/gmc Truck Factory Assembly... 1967-1972 Chevy/gmc Truck Factory Assembly...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-02-2014, 01:20 PM   #3
briank
Does it list finishes in it?
Old 08-03-2014, 12:27 PM   #4
bouncytruck
SKINNY TIRES RULE!
Not that I remember.
bouncytruck 1972 K5
Old 08-03-2014, 04:46 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a thread that hits on finish for some bolts/screws: http://67-72chevytrucks.com/vboard/s...d.php?t=624189
One finish detail to consider is the paint atop the dash between the windshield and dash pad: this was painted to match the pad and has a flat finish from GM to reduce glare. Door strikers were parkerized (phosphate coated) not painted and door latches were natural finish not painted. Parkerize the hood hinges - the resultant finish and function are excellent. I'd also parkerize the body bolts and engine brackets so they can be torqued on without the finish (i.e., paint) flaking off. Here are examples: http://67-72chevytrucks.com/vboard/s...4&postcount=96 and http://67-72chevytrucks.com/vboard/s...&postcount=114
Old 08-03-2014, 05:48 PM   #6
briank
Thanks Pete, thats the info I was looking for. I suppose I should buy an assembly manual as well. Do you have a picture of your engine bay? In particular Im looking for passenger side valve cover view....thanks, Brian
Old 08-03-2014, 05:49 PM   #7
briank
Another thing, werent you looking for a rollbar, I saw a 69-72 k5 being parted out in northwest Montana on Craigslist and he had a rollbar.
Old 08-03-2014, 10:46 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The factory assembly manual is an excellent investment. Happy to provide any pics - LMK if you can't find what you need on my K20 build thread linked in my signature below and I'll post more. My Blazer has CA emissions equip that obscures the pass side of the engine but the K20 lacks this equip and I just grabbed a near survivor 72 K1500 GMC non-A/C LWB that's essentially OEM under the hood down to the battery cables, which is another poss reference.
Thanks Brian! I saw that add. Another member set me up with a roll bar but I appreciate your help. Pete
Old 08-04-2014, 04:02 PM   #9
briank
I did look at your k20....nice by the way! On the blazers wasnt the oil fill cap on the drivers side rear valve cover or was there another on the pass front valve cover. All my engines are different, looking for the correct location.
Old 08-04-2014, 09:10 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks! Do you have A/C? If so, you should have the oil fill tube that plugs into the driver side valve cover in the rear.
Old 08-04-2014, 09:14 PM   #11
briank
No ac, no power brakes either. What goes in the drivers side rear hole then?
Old 08-04-2014, 10:03 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
A plug I believe - check the survivor engine thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=549556
