Old 08-03-2014, 10:13 PM   #26
Ozzy2013
Ozzy2013's Avatar
Re: BIZARRE Spark Plug Color?
Originally Posted by savatreatabvr View Post
How do I perform a leak down test on a budget?
You can buy a leak down tester cheap or rent one at autozone i think i would just buy one .Put the cyl you want to test on top dead center screw the fitting in the plug hole leaving all other spark plugs in the motor and hook up you air hose and pressurise the cyl and see if your valves are leaking or if you have a cracked head or bad head gasket etc.If you have never done it Google it or go to youtube .Good luck.
Ozzy2013 is offline   Reply With Quote
Old 08-03-2014, 10:36 PM   #27
kalbert
You can get a simple leak test kit for ~$50. You also need an air compressor, they range from about $100 for not a very good one up to as much as you care to spend. You can also probably rent one for $50/day. Its possible your auto parts store can rent you the leak down tester for free.
kalbert is offline   Reply With Quote
Old 08-04-2014, 03:14 AM   #28
savatreatabvr
savatreatabvr's Avatar
Originally Posted by Ozzy2013 View Post
Yea i suggested a leak down and comp test a few posts back sounds like he doesn't have the equipment .
Yes I posted my compression test results and no I don't have a "Leak Down Tester"! Why you ask? Because I'm on a tight budget! That's also why I drive a 1973 Chevy truck!
savatreatabvr is offline   Reply With Quote
Old 08-04-2014, 05:37 PM   #29
Ozzy2013
Ozzy2013's Avatar
Just trying to help you out either borrow a leakdown tester or run her till she Blows!
