Old 08-06-2014, 09:56 AM   #1
72CampSpecial
what is the part # for this?
As stated I'm trying to track down a part # and name for this.. came off my HO52 rear end when i pulled the drums off after one of my bearings ate itself. ('72 C20 3/4 ton)
thx..
72CampSpecial is offline   Reply With Quote
Old 08-06-2014, 07:10 PM   #2
bigmac73
bigmac73's Avatar
Re: what is the part # for this?
try emailing Randy's ring and pinion, they might be able to help you out
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-06-2014, 08:42 PM   #3
bollybib
bollybib's Avatar
I got mine from rockauto.com
Dorman 618049 (GM 3663659)
$5.77 shipped for two.
http://www.rockauto.com/catalog/moreinfo.php?pk=15786
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 08-07-2014, 12:38 AM   #4
72CampSpecial
You ROCK! ...just ordered mine for the same price!
Old 08-07-2014, 10:28 PM   #5
airdale94
airdale94's Avatar
Yes, I can verify. Same as the Dana.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
