Old 08-06-2014, 06:11 PM   #1
bob_o
bob_o's Avatar
Front brake line clearance issue with dropped spindles?
I was at the exhaust shop earlier and took the opportunity to inspect the underside of my truck while it was up on their drive-on rack. The thing that immediately grabbed my attention was that the driver side brake line was smashed against the McGaughy 2.5" dropped spindle. Dafuq?? I don't know how I hadn't noticed it until now, but I suppose that's neither here nor there... The passenger side is tight, but not like the other side.
My question is, can I just slightly bend the hard portion of the line until it clears the spindle? Using minimal pressure and without kinking the line, of course... Can I turn the banjo fitting 180º? Has anyone had this issue before??
Driver side:
Passenger side:
Thanks in advance!
bob_o is offline   Reply With Quote
Old 08-06-2014, 06:19 PM   #2
Sodell
Sodell's Avatar
Re: Front brake line clearance issue with dropped spindles?
Bend it very carefully, just a bit to clear. When I put mine on I ran them like that for a bit and then replaced the lines with new ones, and did not reattach to the a arm, I did not have that problem anymore.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 08-06-2014, 06:31 PM   #3
bob_o
bob_o's Avatar
Awesome, I'll do the same. Thanks for the help!
Old 08-06-2014, 06:34 PM   #4
jjzepplin
jjzepplin's Avatar
Looks like you could use some mew line bud. Just sayin.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-06-2014, 06:59 PM   #5
bob_o
bob_o's Avatar
Yep, already got a new pair of lines ordered.
Old 08-07-2014, 07:45 AM   #6
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Yep, I've always had to bend the hard line at the calipers with drop spindles.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
