Old 08-06-2014, 06:18 PM   #1
ScottH
ScottH's Avatar
Question on vent air flow issue
On the 87 I recently bought I just found that the air only blows from the heater duct, not from the vents, regardless of the setting. Did some investigating and it appears that the flap that controls the air flow is not working properly. I removed the glove box and I can move the rod on the evap box but it will only stay in the heat position when the blower is on. I cant tell what it attaches to on the other end.
Can anyone tell me what attaches to the rod that directs the air flow?
Any help is appreciated.
Scott
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 08-06-2014, 09:31 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Question on vent air flow issue
Temperature control is cable, vent controls are vacuum.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-06-2014, 10:18 PM   #3
ScottH
ScottH's Avatar
thanks for the info, guess I'll have to look into it further.
Can anyone tell me where the vacuum for the AC/Heat originates?
Old 08-06-2014, 10:23 PM   #4
Just call me Sean
From the engine vacuum tee on the intake.
Old 08-07-2014, 08:26 AM   #5
chengny
chengny's Avatar
When diaphragm 53 strokes, it directly moves valve 171 and also valve 163 via connecting link 153:
The positioning of these two "valves" is what varies the air flow between the dash vents and the floor outlet. If your "link" is adrift, your system won't shift between the two.
chengny is offline   Reply With Quote
Old 08-07-2014, 10:13 AM   #6
ScottH
ScottH's Avatar
Thanks guys....traced the vacuum line and found it was broken.
Did a quick fix on it & it looks like it solved the problem.
Appreciate everyones help.
Scott
