Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-16-2014, 01:00 AM   #1
phantom309
phantom309's Avatar
22.5'' Alum. Wheel Blanks from Ebay
Hello Folks of the Heavy Haulers forum
Alright recently I was given a 1969 chevy c50 with a 292 and a 4 speed
it has the T150 2 speed rear, runs and drives awesome but...
this truck has had many years of sitting, the tires are pretty bad from the AZ sun as well as being recaps they are pretty rotten it also has brake issues (typical)
knowing that these trucks wheels are pretty scarce I set out to find my self a solution to the issue after exstensive searches on here and other sights i wasnt finding much
a couple of the ideas I came up with were:
#1 find a set of wheels from a bigger truck and have them redrilled to the 10 on 8.75 pattern (problem being: most of those rims have a huge center bore and the C50 pattern would interfere with that)
#2 was to locate a set of wheels for a ford F450 or F550 they use a 10 lug pattern that is only 1/8" bigger... (problem with these is the center bore is a half inch bigger and they come in 19.5 only (you cant really get a very tall tire on a 19.5 rim)
#3 have wheel adapters made to adapt the big 10 lug (10 on 11.25) to my hubs, this could work and very nicely but that would be pretty spendy
at least thats what my local machin shop said...
#4 is the most important one and the one I'll go with:
looking on Ebay under wheel Blanks I found a tiwain company that sells wheels that are completely solid aluminum (forged) and have an 80MM center hole, they come in a 22.5x12.25 or a 22.5x8.25 PERFECT!!!
the 8.25's sell for 209.00 a wheel
the 12.25s sell for 230.00 a wheel
For a guy on a budget (me) thats pretty awesome I plan to buy 2 of each and run super singles on my 69 i plan to make it a pickup and I think running a super single on the rear will look pretty cool.
I am planning to run a 445/65r22.5 out back and a 285/65R22.5 on the front
i want a taller tire in the rear to help with top speed.
Now as far as machine work goes thats the question that I have.
What would be a decent price to have 4 of these wheel blanks drilled to my lug pattern and center bore?
My other concern is brake parts for that axle I know it needs wheel cylinders and pads in the rear anyone have a source for these?
link for the 12.25 super singles:
http://www.ebay.com/itm/181111803868
link for the 8.25 super singles:
http://www.ebay.com/itm/181277587905
"mary lou" 1938 GMC T155 project (on hold)
"mearle" 1966 dodge D100 4x4 (sold)
"candace" 1969 chevy C50 (free truck!!!)
"kelsey" 1976 chevy silverado 30 CS (traded)
"maxwell" 1979 cheyanne 1 ton long box 4x4 (sold)
"polar bear" 2013 dodge durango R/T (mamma's rig)
phantom309 is offline   Reply With Quote
Old 07-16-2014, 05:10 AM   #2
4x4toy
Re: 22.5'' Alum. Wheel Blanks from Ebay
That is cool. I would leave the wheel solid and not have hand holes. If could afford the super single tires I would put four of the wide wheels on my 1961 C60.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 07-16-2014, 05:23 AM   #3
phantom309
phantom309's Avatar
I think if I could afford it I would do the same!
and you're right I think I will leave them smooth!
retreads for the supers are only $250ish each on Ebay
Old 08-05-2014, 03:17 PM   #4
colgad
colgad's Avatar
Changed my rearend to TopKick so I can use 445/50/22.5 super singles and have rear disk brakes.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-05-2014, 10:25 PM   #5
phantom309
phantom309's Avatar
That looks freakin sweet!
Old 08-06-2014, 10:51 PM   #6
rkn463
rkn463's Avatar
What is the hub size and bolt circle on the Topkick rear? It looks a lot larger than stock.
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 08-07-2014, 12:05 AM   #7
colgad
colgad's Avatar
It's just like the 10 bolt Semi's, Bolt circle size 285 mm I believe.
Hub centric
Old 08-07-2014, 08:32 PM   #8
rkn463
rkn463's Avatar
Hub centric
That is good to know. What year model Topkick was the donor?
Old 08-07-2014, 10:28 PM   #9
colgad
colgad's Avatar
A 92, there are a bunch out there but a lot have 8 lug 19.5's. They did make 22.5's to fit the 8 lug but they are not common. Most of the heavy TopKicks and Kodiaks had the standard 10 lug Hub centric 22.5's.
Old 08-10-2014, 03:41 AM   #10
63chevyll
gets board easy.......
63chevyll's Avatar
*****en. Love the rear end choice
63chevyll is offline   Reply With Quote
Old 08-14-2014, 06:07 AM   #11
4x4toy
colgad. Nice, we need more info on your build.
Old 08-14-2014, 09:07 AM   #12
colgad
colgad's Avatar
Not much to tell really it's a 67 C50.
I cut most all of the frame off of just past the rear cab mount
I used the rear frame of the 92 Topkick so I would have a more modern suspension. I removed two spring leafs, leaving only one really thick leaf.
A large swaybar and disk brakes.
The original 327 is still running with the granny 4 speed. Normally you would not have to use 1st gear but with the rear end changing from a two speed 8.22-1 to 4.11-1 first gear is needed.
This will not be a rocket even after I remove the 327 to the 454 I have in the shop. But will roll down the highway at 2400 at 70.
My biggest challenge now is to find a C60 83-88 front axle so I can run 22.5's with disk brakes. Currently I have the brakes bleed and are working but I do not trust the front drums and as you all know they are the 20" widow makers
The TopKick front axle is to wide and the tires would stick out.
thanks for asking about my C50 pickup project.
Old 04-26-2016, 07:12 PM   #13
beck-529
It appears the 8.25 blanks are still available. There are no 12.25 blanks currently on ebay.
Has anyone tried these?
I don't think any one answered the OP's queston of having them machined. They would need the center bored and the bolt holes drilled. I don't know if I would have holes machined into the face or let them smooth as suggested here.
beck-529 is offline   Reply With Quote
Old 04-26-2016, 07:58 PM   #14
rkn463
rkn463's Avatar
I spoke to the guy at my machine shop and he estimated 35 dollars per wheel. Keep in mind he estimated my axle at 120.00 to 180.00 and it came out to 300.00. In his defense the axle turned out to have to be done by hand and he said he can put the wheels on a machine so I would assume that would be far more accurate.
If anyone has or does try these I'd love to see pictures!
-Richard
Old 06-23-2016, 01:07 PM   #15
Swiftshifter68
Swiftshifter68's Avatar
In the same vein, would these work for these big trucks? (Set of 12x, so guys could go halfsies?)
http://www.ebay.com/itm/12-22-5-x-7-...3D181111803868
Swiftshifter68 is offline   Reply With Quote
Old 06-23-2016, 10:16 PM   #16
rkn463
rkn463's Avatar
Those will not fit the trucks I have - 67c50, 68c50, 89c60. All of them have a 6.25 hub diameter and an 8.75 bolt circle. I think some of the larger tucks may have used what you found but I don't know for sure.
-Richard
Old 06-26-2016, 12:46 AM   #17
mrolds88
Colgad, I was looking over your pics a couple of posts up and noticed a couple of things. First is the driveshaft. It's not in phase. Looks to be off about an eighth of a turn. You should get vibration this way. And second, is the splitter block for the rear brakes mounted to the frame? If it is, you need to remount it onto the rear. The way it is set up now (if it is mounted on the frame) will fatigue the hardlines and something will fail. Not busting on you, just want the truck safe and whoever rides in it too.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
