Old 08-07-2014, 12:34 AM   #1
C.W
Lowered and bagged guys driveshaft ??
I currently have a rear flip in my 86 Burb with the 2pc drive shaft and the diff set back to account for drive shaft length. I am planning to swap to a 1pc as I have it already and am tired of replacing carrier bearings. I would like to center the diff so the wheels dont look out of place and am wondering how much you guys have had to shorten the shaft to make this work?
Also bags are in the future plans and hope to lay frame. What have you guys done about the drive shaft length?
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver.
86 Short box just starting the build.
86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come!
98 Cheyenne Ext cab short box 2wd. Driver and maybe future project.
C.W is offline   Reply With Quote
Old 08-07-2014, 07:15 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Lowered and bagged guys driveshaft ??
The same amount.
In other words, if you scoot the wheels forward in the opening 3/4" you'll need to shorten the shaft that same 3/4" or so (it's not totally precise because of the dynamic slip in the trans/yoke).
k
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-07-2014, 02:00 PM   #3
kevinr1970
Most flip brackets I have seen have the hole for the pin on the leaf spring off-set to correct for that. But that might require the driveline to be shortened?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
