08-07-2014, 08:36 PM | #1 |
2001 up ac in 67-72 cab
Has anyone tried this? Just thought it would make a very tidy install compared to the big factory ac. My truck has ac already but I have a 2001 donor truck and could just swap it all out. I'm starting the ls swap and trying to use as much new parts/ technology as possible. engine accessories harnesses and all.
08-07-2014, 09:02 PM | #2 |
Re: 2001 up ac in 67-72 cab
Subscribed, I wanna know about this too.
I think it'd be pretty difficult dealing with the electronics, you'd probably need the BCM from the donor truck...
71 K20 64 GMC mud truck |
08-08-2014, 12:13 PM | #3 |
i've got a 2008 donor and i was planning on doing the same!! i'm in too
08-08-2014, 12:39 PM | #4 |
the question is, has anyone swapped in an ac system from another vehicle/year, if so what fits best??
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
08-08-2014, 12:44 PM | #5 |
This has come up before and I seem to remember someone saying they've done it.
I have a hard time believing because the space under the dash is much smaller on these trucks than newer trucks.
08-08-2014, 01:09 PM | #6 |
I'm wondering why none has made a full electric unit. There is plenty of room under the hood to put an electric motor driven compressor and condenser. Maybe even add a second battery to help power it
08-09-2014, 12:34 AM | #7 |
Here you go! This is board member ls1nova71. It's on an ls motor swap, but should give you some ideas if nothing else. Check out his full build - he does some really great work!
http://ls1tech.com/forums/conversion...0-4l80e-7.html |
08-09-2014, 01:23 AM | #8 |
Im in looking to put A/C in the 68 GMC and have been studying how to do this cheaply.
08-09-2014, 08:01 AM | #9 |
Check out the Young Frankenstein crew cab 72 build, pretty sure he did it.
08-09-2014, 10:51 AM | #10 | |
