#151 | |
Re: What did you do to your Blazer/Jimmy today?
#152 | |
#153 |
Looking GOOD! That's just what I need - I'm re-motivated!
#154 |
Is that a Bronco Bob roll cage? If so how do you like it? I have been thinking of getting one but wanted to see what one looked like installed in a Blazer, the pics on there website don't really show much.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
#155 |
Boosted Member
YES!! More pics/info on the cage! I have been trying to think up a design that would look good in my 2wd, and I think that might be it!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#156 | ||
Yes the majority of this cage is from "Bronco Bob's" (BB's). Bob bends all the tubing (2" DOM .120 thick) up for you, all you have to do is cut and notch the tubes to length. The portion of the cage in the bed is all bent tubing from BB's. However, I ended up not using the front tubes going down the windshield frame. No fault of BB's. I was not specific when I ordered the cage stating that I needed clearance for the A/C vents in the dash. I could of used BB's front tubes they would have just come straight down to the into the door opening to allow clearance for the A/C vents. So, I had the front tubes bent (1.75 DOM .120 thick here in my home town) to clear the A/C vents and allow more foot clearance getting in/out of the truck. Also, I added two bends in the upper horizontal windshield bar to get more head clearance and also allow the use of the sunvisors. Overall very happy with the BB's set up!! Just a couple of helpful fab'ing tips....I ran into struggles trying to fit a cage under multiple tops (original double wall, original single wall and a Softopper) I started out installing the cage with the plan of having it fit under a double wall and a softopper. So I started with the double wall on the truck thinking the cage would be a tighter fit. Which the sides were very tight!!! When putting on the softopper the cage was way to tall to clear the softopper support bows. I had to drop the middle hoop 2" in order to clear to Softopper front two bows. So everything was great in till I found a single wall top on craigslist. I bought it wanting to replace the double wall. Well.....believe it or not the single wall cage will not fit under the cage unless you significantly shorten the height of the hoops or have BB's bend the hoops to a lesser width. So when our ordering from BB's make sure you state if you have AC or a double vs single wall top!! One last thing you might want to keep in mind when you fab'ing up the mounting plates, you might want to keep the outside edges within the bedside rails so that you can pull the entire cage out of the truck to paint it or remove it for any reason. If you guys want any more specific pics let me know!!! Hope this novel helps!! ![]() Eric |
#157 | |
Boosted Member
Eric,
Thanks for the info! Can you elaborate a bit more about what you've got going on with the cage to frame connections? I think I see what you're up to, but some pics of the finished product would be great when you get them. Quote:
#158 |
![]() Join Date: Nov 2007
Got a large summit order in. Finished putting my transcase back together after 3+ weeks of waiting on various parts from different places.
#159 |
TTT... I been working on my factory air conditioning. I replaced the POA valve, the expansion valve,the water control valve and the reciever dryer, servise the system back up with R-12. I am getting about 54* at best. That's all I am going to that system for awhile.
I put on some new front brake pads today semi easy job. Next I am going to put a new engine in it as soon as it cools down here in Houston TX.
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
#160 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Nothing recent on my Blazer. Not sure I'll have time before it snows but would really like to install the slider rear windows. I've been tinkering with a 1/2 ton LWB 1972 GMC 4wd I recently got: http://67-72chevytrucks.com/vboard/s....php?p=6801778
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#161 |
![]() Join Date: Jan 2014
Are you able to roll up and down your windows? There appears to be clearance issues with the window crank on your picture or could just be the angle of the picture. @1972 Jimmy
#162 |
That's a cool truck Pete. I'm always looking around for trucks. I like them 4x4's
#163 |
Put my radiator in, lower hose. Then put cup on my replacement fender, filled all my welds up, sanded down and some rattle can primer on them to keep from rusting over night.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
#164 |
You are correct! that is the only downfall with the cage. It's really tight to the door. I need to open up the door to roll up and down the windows. not that big a deal for me, we will only be driving it in the summer.
#165 |
Finally painted last week, new bumper and grille added yesterday.
Don aka Rocket_Man 72 K5 Blazer 454 CI 2002 Honda VTX 1800C |
#166 |
![]() Join Date: Aug 2014
Brought my pasture find home.
A lady I work with overheard me talking about wanting a 1st Gen Blazer or Jimmy and said "I think my husband has one of those out behind the barn. You can probably have it if you will just come get it'. I picked it up today!:chevy: |
#167 |
that is so not right... lol, nice score.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#168 |
Nice score!
#169 |
Wow!! Nice score!
#170 |
Why don't these things happen to me? Nice!! Congrats on your barn find.
I spy 3 things I'll buy from you if you are going to scrap them. The spare tire carrier, front buckets and that factory air cleaner. |
#171 |
Carpe manana
Nice!! Are the shoulder belts listed on the SPID?
#172 |
Can t beat the price with a stick....what are your plans for it? Nice find, ya never know where these things will turn up
#173 |
Not unless they are part of one of the packages.
#174 |
#175 |
I plan on using them. But if things change I'll let you know! (and as many times as I've already changed my dream/direction already, there's a good chance)
