Old 08-11-2014, 03:21 AM   #1
travis hillard
Lift hatch hinge repair
Looking for some much needed advice! Scored a nice top with lift gate for 50 bucks at one of those pull it yourself places. Could not beleive there sat a 72 CST complete except the wheels. Well after getting it home realized the metal structure in the hatch is rotton or broken loose. Has anyone repaired this or have any pictures of what it should look like for the hing mounting. Thanks alot!!
travis hillard is offline   Reply With Quote
Old 08-11-2014, 06:35 PM   #2
DANTES JIMMY
DANTES JIMMY's Avatar
Re: Lift hatch hinge repair
if you are referring to the hatch side there is a thread here that someone split it open and repaired an bunch of stuff and repaired it all
DANTES JIMMY is offline   Reply With Quote
Old 08-11-2014, 06:41 PM   #3
DANTES JIMMY
here try this one
http://67-72chevytrucks.com/vboard/s...d.php?t=438402
Old 08-11-2014, 07:16 PM   #4
travis hillard
Yes talking about hinge mount inside hatch. I could not open the link you had posted.
Old 08-15-2014, 02:17 AM   #5
travis hillard
Got the link to work and found out what Ill need to make for the hatch. But while taking off the hatch supports where it bolt to the top found that plate rusted away on the one side. Guess ill be cutting into the top also. Thanks alot for the link!
Old 08-24-2014, 07:15 PM   #6
Bentblazer
Bentblazer's Avatar
Might be helpful http://67-72chevytrucks.com/vboard/s...d.php?t=438402
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 08-24-2014, 10:30 PM   #7
travis hillard
Thanks for the link! I had ran across this in my searchs but it does not seem to give much detail on cutting the hatch apart or attaching the halfs back together. Anyone with information on this? Thanks again for the information!
Old 08-25-2014, 07:05 AM   #8
Bentblazer
Bentblazer's Avatar
Check post 29 & 30, I used a 3M product to mate them back together, cant remember which one
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 11-24-2014, 05:58 PM   #9
Senorx
Senorx's Avatar
Any tips or tricks on removing the hatch glass and re-installing it?
Senorx is offline   Reply With Quote
Old 12-09-2014, 12:56 AM   #10
robs71k5
K5drive
robs71k5's Avatar
You can cut a hole between the hinge mounts on the upper side as if the hatch was on the truck. That is after your successful at removing gone hatch from the truck. The rusted out mounting plates once de riveted will slide towards the centre and if you cut the whole the right size it will fall out if you turn the hatch upside down. I sell direct replacement re manufactured mounting plates if required as they are difficult to make so I have made a tool that presses them out to identical to original only a slightly heavier gage There is no need to separate the two halves as it is tricky to do so with causing damage elsewhere but it has been done and no two hatches in my experience have seperated alike. But although you can carefully do the fibreglass repairs suscessfully without dismantling. You will need lots of patients starting with one layer of fibre glass and building up from there especially around the windows radiaii the first coat of fibreglass should be waxed resin and after its cured it needs to be dewaxed with acetone before building layers
I do have a couple hatch shells that are nearly rebuilt should you require a replacement hatch. My hatches include new mounts installed no windows installed makes shipping possibly tolerable . Windows install easily with shims .Good luck !
robs71k5 is offline   Reply With Quote
Old 12-09-2014, 03:12 AM   #11
Senorx
Senorx's Avatar
PM sent, Rob.
