08-11-2014, 09:29 AM | #1 |
Is this normal and is it from the engine or trans?
Hey all,
I have had this question in my head for a long time but just been ignoring it. I have a 2011 5.3 w/6L80. You know those times where you slam on the gas and the tranny kicks down but for whatever reason (someone cut you off) you have to let back off real quick? Well when I do that my tranny seems to not know what to do for a few seconds but there is still all this buildup in the engine (high rev)and then it sounds like my truck farts and all that pent up energy is released, is this normal? |
08-11-2014, 04:46 PM | #2 |
Re: Is this normal and is it from the engine or trans?
no...
08-11-2014, 10:39 PM | #3 |
Enjoying left field
Yeah, vehicular flatulence is never good
08-11-2014, 10:56 PM | #4 |
Lol, it seems to release through the exhaust but sounds funny
08-12-2014, 11:23 AM | #5 |
Can be adjusted in your tune...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-12-2014, 12:24 PM | #6 |
Guess I will have to wait till I get HP tuners because I hate driving to my tuner.
08-12-2014, 12:55 PM | #7 |
meowMEOWmeowMEOW
Not a single code or anything happens during this? I can honestly tell you I've never heard of a problem like that...
IF there was a way for power to "build up", then it would all be lost in heat and slip at the convertor if it didn't know where to go. Unless that noise is you massively slipping past the convertor... The valves go through their events each power cycle, so its not like you can actually "trap" air or fluid anywhere to build up. When you stab the gas and lift off right away, there is something called DFCO with is basically decel fuel cutoff or enrichment. Depending on your fueling and how that is setup, you could be in a fueling situation that triggers the odd behavior. Without a log or the tune live it may be hard to tell.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-12-2014, 03:44 PM | #8 |
Thanks for all the replies, much appreciated. No codes at all, it's weird... only happens when I stomp on it, tranny kicks down but I let off the gas before the power kicks in. it almost sounds like an air brake like the big rigs have. Other than that she drives good.
08-12-2014, 08:54 PM | #9 | |
meowMEOWmeowMEOW
