08-11-2014, 01:22 PM | #401 | |
Still Learning
Re: My daily driver/beater : How I turned lemons in lemonade
I had a question. What did you do to address your pinion angle at ride position? I may have screwed the pooch on mine as I have definite vibration from 50 mph up. What gears are you planning on running in this truck? thanks, |
08-11-2014, 01:35 PM | #402 |
Watch out for your cornhole !
Mike,
I haven't set the pinion angle yet because I'm waiting on my dropmember. It will move the drivetrain up some so I need to get it installed and the drivetrain in final location before I set the angle and weld the saddles on. Currently I just eyeballed it close and tightened the u bolts. Once I do get everything in place, I'll set pinion angle at ride height and weld it there. My truck will be a "drive around low and air it out when parked" kind of truck so that should serve me well. If yours is off, you can cheaply and easily get pinion angle shims to install and adjust it up or down as needed. The truck has a stock (worn out) 350, Turbo 350, and 3.08 geared 12 bolt in it. I'm no where near a hotrodder so the 3.08 suits me greatly as I mainly just drive down the highway minding my own business.
08-11-2014, 02:01 PM | #403 |
Farm Truck
Do you use paint stripper then blast, to help loosen the old paint?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
08-11-2014, 02:04 PM | #404 |
On the areas I blast, no. I just laid them on work stands and dusted the original paint and primer off with the blaster just takes a second and sure beats the beating of sanding areas like door jambs and inner fender panels.
On the outsides, I used stripper to remove the majority of the paint. Then pressure wash thoroughly to get all stripper residue off. Then an hour in the hades sun we have here to dry. After that sand with DA and 80 grit.
08-11-2014, 03:14 PM | #405 |
The rear setup is looking good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
08-11-2014, 03:40 PM | #406 |
Had to order a new tailgate. Mine is just too far gone to ever be nice. Dents and holes rusted through it.
I did step up with my big boy pants on though and bought a genuine GM approved, made in USA one from Mar-K. I'd rather be broke and have a made is USA part than save money and buy one made in Sum Flung Dung.
08-11-2014, 04:13 PM | #407 | |
Still Learning
08-11-2014, 06:29 PM | #408 |
I'm just glad to be here!
Progress looks good Kevin. I just now got caught up while still on Vacation. I know Texas heat is killer but its 107 here in Phoenix today...they say its a DRY heat, well so is an oven, hot is hot at anything above 85..lol
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-20-2014, 09:05 PM | #409 |
nice work!
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
08-21-2014, 04:58 PM | #410 |
So how's it going? We need our weekly Kevin update........
08-22-2014, 04:21 PM | #411 |
I've been working from 3:30 in the morning till night on this thing. Somewhere around 60 hours per week I'd guess besides my full time 56 hours per week at the fire department. I have next month off from work so I can get even more serious about putting in the hours. Travis at ProPerformance had said he thought dropmember arrival would be possible around the first of September. I'm walking a line between pestering him and trying not to be a pain on his side, letting him know I'm serious about getting this thing done by February. I'm hoping it all goes through. I'll have a solid month set aside to work on the truck as many hours as I can humanly remain upright.
Repairs to rear bed sill. Made a patch out of scrap metal. Bent with my little press brake. Trimmed and welded in. Hammered the bed rails into a shape similar to what they originally were and then capped them off for a cleaner look. Built new subfloor with ten bed to frame mounts. Welded metal bed floor to bed with about a zillion plug welds. New angle strips made out of 1.5 inch angle iron. Sandblasted the entire bed to nice white metal, did body work and then epoxy primed and painted. Shot Raptor liner inside bed and gate to really finish it off. Floor is still kind of beat up but I just don't care. I have no interest in slicking out a pickup bed floor. Today I started on the fender and steps. Everything is going to bare metal first step. Wait till next month. I'm going to go full mental on working on this thing.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 08-22-2014 at 04:27 PM. |
08-22-2014, 05:11 PM | #412 |
That's just what the doctor ordered! See I knew you had been busy.....Good work!
08-22-2014, 05:29 PM | #413 |
08-22-2014, 07:13 PM | #414 |
Tx....
What did you think of the Raptor liner? Kit or??
08-22-2014, 07:19 PM | #415 |
Raptor liner is fantastic. I can't say enough good about it. I bought the kit about 5 years ago and sprayed the inside of a cab with it. That used half of it. I saved the other half all these years and finally used it this morning. It's about fool proof, comes with its own gun, and the finished product is nice to look at.
08-22-2014, 08:10 PM | #416 |
I cant wait to see what happens next ,that bed looks great .
08-22-2014, 08:56 PM | #417 |
Sun finally went down enough that I could get some better pictures.
Inside of bed New angle strips. They're just generic angle iron that I drilled a bunch of holes into for plug welding in place. The bed floor and sides were way, way out of straight. This old bed was very abused in its previous life. It took a lot of pulling and clamping to get it back straight. 75 bucks don't buy much of a stepside bed anymore I guess. Mar-K tailgate is super high quality. Made right there in Oklahoma.
08-22-2014, 09:02 PM | #418 |
awesome
08-22-2014, 10:45 PM | #419 |
This is such a great build. I have heard nothing but good things about raptor bed liner.
84 step side 87 swb |
08-23-2014, 10:11 AM | #420 |
I know the pieces fit
Awesome work, as usual. I'm the same way about liner over bed dents, all that means to me when I see it is that its still used as a truck.
08-23-2014, 02:39 PM | #421 |
Lookin' good!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
08-23-2014, 09:42 PM | #422 |
The bed looks great!
08-24-2014, 03:56 PM | #423 |
Nice!
'68 SWB Fleetside '98 K1500 Silverado |
08-24-2014, 06:31 PM | #424 |
Camaro Club
You may not be giving up the color but even in black and white i can tell it is a matte finish. haha
08-24-2014, 06:51 PM | #425 |
Where did you get your tailgate chains and hardware ?
