#26 |
Re: 68 c10 2wd in Sacramento, CA
well... it would appear that my progress is about to come to a screeching halt, as I don't have the money for a new drive line or to have mine shortened... DOH!
I'm going to try and get as much other crap done as possible so I can just stick it in (yes... that is what she said).
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
#27 | ||
#28 | |
![]() Join Date: May 2013
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
#29 | |
Furthermore, I'm only moving fast for two reasons, 1.) my boss doesn't want the truck here long, and 2.) I don't want to give my wife enough time to change her mind about how much time and money she is letting me put in to this project ![]() ![]()
#30 | |
edit: I was just looking at your truck thread, you might be interested in the bed floor I have, its metal instead of the wood, it isn't in fantastic shape, but it's workable.
#31 |
well, I finished the frame. Welded in boxing plates, and ground/smoothed my outside welds. Put a coat of rattle-can-de-noire on the frame (black spray paint). installed the motor, cut the exhaust down and re welded it. plumbed all the brakes except the last line up to the prop valve (which I will finish today). and now I am starting on some of the body issues before I reinstall the body on the frame.
![]() the long tube headers contacted the new a-arms a bit, so I put a jack under the collector flange and heated the pipes a bit till it bent away now there is about 1/2 " clearance. ![]() ![]()
#32 |
This is where $h** gets serious... I am trying my hand at body work for the first time. I have done some things with motorcycles, but not cars really...that being said I decided to cut a hole in the side of my truck
![]() I had a panel outside the door post that had been repaired before and the bondo was so thick, it actually fell off... ![]() so I cut it out ![]() ![]() here is the piece I cut out of the 67 parts truck I have at home ![]()
#33 |
I drilled out all of the spot welds in the door jam because I wanted the seam to remain in the door jam.
#34 |
Nice work. Braver than me so far. If the inner cowl on your parts truck is decent and you don't need any patches from it, I might want it for mine. Mines pretty well rotted.
#35 | |
I have to get rid of it asap. I live in a sub division and the code enforcement cops have allr3ady been by threatening me so if you don't want it it will be gone by the weekend
#36 |
If I had room for it, I'd take you up on that. I'm in the same boat as you, no space. I had to rent some storage space just so I'd have a place to keep mine. How's the bench seat?
#37 |
Eh... so so. I just need to get rid of the thing fast. I don't want a fine for a parts truck.
#38 |
If you need a part, send me a pic of exactly what you need. If I have to cut it off I will need to do it today. I am taking the truck to the chevy parts guy tomorrow afternoon. I can remove whatever part you need and hold on to it.
#39 |
Is the parking brake assembly intact? I could use that. How about the AC controls (if it had AC)?
#40 |
didn't have ac, and the parking brake s gone, I have wheel chocks keeping it in my driveway. surprisingly the actual brake system still works though
#41 |
If I was all hot to start welding in patch panels, I'd jump on that. But, thanks for the offer. I don't want to take up your time doing stuff for me when you have your own truck to work on. If I had time, I'd run over and grab what I need myself. Damn full-time job! Don't have time to do any of the real important stuff.
#42 | |
#43 |
no1udknow I have room for that if you still have it.
#44 |
Sorry, the parts truck is gone. I had to uave it gone by this last weekend or I was going to get a fine from the wonderful Galt police department. It worked out though because I took an extra carburetor I had along with me and traded for a one piece drive shaft and some emblems I wanted
#45 |
damn missed it
![]() Funny how you have to pay morgage and taxes and someone that doesn't tells you what you can or cannot do. . |
#46 |
Ok... made some serious headway today. Got the driveli e and new u-joints installed
![]() it's a one piece now... so glad im done with carrier bearings. then I got the patch panel finished on the passenger side ![]() ![]() I will be doing the rest of the body work like bondo and paint at home so I threw some rattle can on the bare metal to keep it from rusting after I ground it down. ![]()
#47 |
My welds arwnt perfect, but this is my first attempt at bodywork so I am satisfied. I'm sure I will get better with practice.
Now that the patch is done, I need to put the truck back together so I can take it home. My boss wants me to get it out of the shop. So this is how I transport my cab around... a trailer and a golf cart ![]() ![]() I got the cab installed, after shortening the frame, everything still lined up perfect. ![]()
#48 |
I started getting a few things hooked up and the new brake system installed. I have seen guys say they had to use special brackets for the booster, I drilled some new holes for the top bolts, and trimmed the bracket at the bottom to clear the steering column bracket. The only ossue I have so far is the shifter arm on the column hitting the booster but I will work that out.
#49 |
wanted to do a quick run down of the cost thus far,
$1000 for the truck that I traded for this truck :-) $ free new front suspension and disc brake system $ 60 new tires and an extra set of rims $ 40 cpp 6 lug rotors $ free drive line $ 30 u-joints $ 20 exhaust gaskets $ free bedside, fender, and cab patch $ 20 brake line and adapter $ 35 title transfer _________________________ total $ 1205
#50 |
Wow! Way to get it done on a budget!
