08-13-2014, 08:00 PM | #1 |
Need front coil spring info for 72 C10
I recently bought a 1972 C10 and my front springs have been cut to lower the truck. However the previous owner did a terrible butcher job on them and they are actually cut 2 different heights.
So I was hoping that someone could tell me what the stock height is for a front coil spring for a 1972 C10. Thanks! |
08-13-2014, 08:23 PM | #2 |
Re: Need front coil spring info for 72 C10
You can buy brand new coils from your local NAPA store
08-13-2014, 08:30 PM | #3 |
I understand I can do that but I would like to know how much mine have been cut so I can buy a pair that will be similar in ride height then.
08-14-2014, 08:17 AM | #4 |
Are you looking for coil height or frame to ground?
Napa website gives all the specs for the springs. Look up your truck. It will give spring rate,height and diameter of coil and outside diameter of the whole spring. For stock springs 1/2 3/4 1ton. Found it very usefull for getting the springs right for my c/30. |
08-14-2014, 09:15 AM | #5 | |
08-14-2014, 09:19 AM | #6 |
08-14-2014, 10:42 AM | #7 |
This listing is for a 72 1/2t standard duty replacement spring
looking at a picture, it appears to have 7 coils/rings. ID = 3.68 bar diameter = .750 Spring rate = 722lbs per inch Load = 2406lbs Installed height = 10inches Free height = 13.18 inches This listing is for a 72 1/2t heavy duty replacement spring This also appears to have 7 coils/rings ID = 3.68 bar diameter = .810 Spring rate = 1015lbs per inch Load = 2600lbs Installed height = 10inches Free height = 12.56 inches Hope this helps
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
08-15-2014, 08:30 AM | #8 |
Thanks for the replies! It helps out a lot!
