Old 08-14-2014, 01:29 PM   #1
curvedglass
curvedglass's Avatar
Side view mirror question
My 63 didn't come with a passengers door mirror. I want to buy one from LMC. My issues is that I am worried that just screwing the mirror to the door doesn't sound too solid. Is there a backing plate that belongs behind the door that those mirrors mount to?
curvedglass is offline   Reply With Quote
Old 08-14-2014, 04:20 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Side view mirror question
There are factory demples on back side. Use those to locate base. I used washers and nuts to hold in place.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-14-2014, 04:23 PM   #3
LVPhotos
LVPhotos's Avatar
Here is side view.
Old 08-14-2014, 04:41 PM   #4
1963c-10
1963c-10's Avatar
The factory installed backing plates in both doors, but you will need nuts and lockwashers for the install on the pass side. Position is same as driver door, so make template off of it or take measurements from it and you'll be fine. Be sure to order the exterior gasket also.
1964 Short bed trailer
Old 08-14-2014, 07:31 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I used serrated flange nuts inside the door. This helps spread the load and also makes it easier to attach to the screws as there are no washers to fall inside the door. Also, I highly recommend the outside gaskets from LMC. They are molded with a ridge around the edge and last indefinitely. All others I'm aware of are cut from flat rubber stock.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-12-2015, 12:25 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by LVPhotos View Post
Here is side view.
How's the view with the small mirror that far away.
I noticed most newer passenger side view mirrors give you more view. As in: 'objects in mirror are closer than they appear'
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-12-2015, 03:20 PM   #7
LVPhotos
LVPhotos's Avatar
View? What view? Na it's ok, can see top of bed and about a foot out to side. By the way I am in Eugene working.
