Old 08-14-2014, 10:54 PM   #1
cerial
cerial's Avatar
Manifold to header flange gasket.
I picked up some ram horn manifolds for $5 today. They are square bore and will give more room for removing the angled plugs. I wont go into the why just know this will be the 3rd exhaust system I built for this truck in 6 months On the upside I am getting really good at building them and this should be the last one for a while.
Anyway back to the manifolds. I have some block hugger headers on there now with a 2" outlet. I really don't want to play with doughnut gaskets again. I would love to use a flat gasket between the mating surface of the flange and manifold if at all possible.
Should I use springs or not with the current exhaust studs?
Any tricks/recommendations on gaskets that wont leak? I like my exhaust quiet so any leak will end up causing yet another redesign.
The exhaust is connected to the heads with the passenger side dropping down and back while the drivers side drops down then 90's into the passenger pipe then to two junk mufflers (they will be replaced with a newer cat/quiet flow) that have two rubber clamps in opposing directions to provide a very ridgid setup.
cerial is offline   Reply With Quote
Old 08-15-2014, 08:52 AM   #2
geezer#99
geezer#99's Avatar
Re: Manifold to header flange gasket.
Use the doughnuts, no springs and use brass nuts. Don't make the rest of the exhaust rigid.
You want it to flex with the motor. If it's rigid then the doughnuts will start to leak.
Old 08-15-2014, 09:28 AM   #3
Rich84
Rich84's Avatar
$5 ram horns..Good deal. Could you post some pictures when you get them on?
Rich84 is offline   Reply With Quote
Old 08-15-2014, 02:28 PM   #4
bonuts
Look into Remflex for your gaskets. I have done a few gaskets myself with this stuff and have never had a problem using it with headers or manifolds.
Terry
1967 Chevy short stepside
1982 S-10
1975 C-10 2wd Short box
2014 Silverado
bonuts is offline   Reply With Quote
Old 08-17-2014, 06:03 PM   #5
KevinD85
KevinD85's Avatar
I did copper gaskets and stage 8 locking fastners on my colectors and they work great.
not sure if they would work on those though.
1986 chevy k10 silverado rust free from oregon 350 crate big cam,headers and 2.5" duals with an x pipe.
2001 subaru 2.5 rs with a full wrx sti swap track car project
1991 Lexus Ls400 rwd drift toy
2012 lexus is350 awd daily driver
KevinD85 is offline   Reply With Quote
