07-01-2014, 02:07 AM | #1 |
Coil Spring Rear End Suspension Cup Bolts & Washer
I was installing my coil spring rear end on my 1968 Chevy Truck C10 last night and ran into problems with the coil spring cup bolts and washer. The reproduction coil spring cup kit that I purchased came with hardware. My dad and I tried to install the coil springs and cups with the reproduction bolts but the problem was the bolts were to short were they wouldn't catch to the cup with the nut on it. Lucky my dad tells me every time to save everything that I take off my truck. I had the original bolts for the coil spring cup and there was a difference in size. Here are some pictures to show you want I mean.
Thanks! Craig - Every day is a new opportunity. You can build on yesterday's success or put its failures behind and start over again. That's the way life is! |
07-01-2014, 08:11 AM | #2 |
Re: Coil Spring Rear End Suspension Cup Bolts & Washer
subscribing
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
07-01-2014, 09:06 AM | #3 |
Had the same probelm, used my old bolts
07-01-2014, 11:30 AM | #4 |
The Older Generation
You would think something that simple would be really easy for them to get right.... Makes you wonder.. LockDoc
07-01-2014, 11:34 AM | #5 |
Just went thru the same problem on my 67. Had to go to home depot and get 4" grade 8 bolts and hardware
1967custom |
07-01-2014, 11:45 AM | #6 |
Same thing. Bought mine from Classic Performance Products (CPC) on eBay. Just a minor irritation though.
07-01-2014, 01:12 PM | #7 | |
07-01-2014, 09:29 PM | #8 |
I've said it before and I'll say it again, repop crap sucks. You are restoring an old vehicle, restore, don't replace. Just as new cars are crap so are new parts.
07-01-2014, 10:42 PM | #9 |
Actually, the cups I got from Classic Performance Products were a dead-on match to the originals. The hardware was the only problem. I thought it was still a good buy for $20.00.
07-02-2014, 12:01 AM | #10 |
Ewww i got a set of the ccps in my tool box ill hsve to remenber to get long bolts
08-16-2014, 06:19 PM | #11 |
Tags |
1968 truck coil spring, chevy truck c10 rear end, coil springs, rear end suspension, suspension 1968 |
