Old 08-17-2014, 10:07 AM   #1
ACII
LS1 stand alone harness expert needed
Hy all
after i blew up my old smallblock i decided to go with modern setup...sofinally i got a LS1 out of a CAmaro z28 of 1999.
The engine has only around 60000 miles on it....
So far the hard work is done ...the engine / transmission is sitting in the 51 pickup..
The next step is to strip the harness... i found a lot of information in the net, so i just have some last questions , as u can find in the attached file.
Hope u will find a second for me
Thanks a lot for help
CU
Achim
ACII is offline   Reply With Quote
Old 08-17-2014, 10:16 AM   #2
47 Fasttoys
47 Fasttoys's Avatar
Re: LS1 stand alone harness expert needed
Yes, on all accounts. Now this is assuming you will not try and have traction control or emissions.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 08-17-2014, 10:17 AM   #3
ls1nova71
ls1nova71's Avatar
Looks like you prettty much have it, but double check here. Its for a 5.3, but they are real similar to a 99 LS1 http://lt1swap.com/99-02_vortec_pcm.htm
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-17-2014, 11:46 AM   #4
ACII
yes i dont need an traction control and emission stuff :-)
I assume that i can remove all the TPS to TCS wires ????
Can i generally hook up all the pink wire to the ignition power ?
I already used the LT1swap website...so far i could through it until the C100 / 101 / 105 blugs...
Hope u can help me ....
Achim
Old 08-17-2014, 12:30 PM   #5
ls1nova71
ls1nova71's Avatar
Yes, you can remove the TPS to TCS wires, and also yes on the pink wires , they are ignition power.General rule of thumb is pink is ignition power and orange are constant power.
