Old 08-17-2014, 02:25 PM   #1
FLYNAVY30
Quick One....Oil pressure gauge fitting
'72 C20, does anyone know what the size is on the fitting on the back of the factory wet oil pressure gauge? Ive got a 4 AN braided line coming from the motor, but need an adapter for the back of the factory gauge. Thanks!!
FLYNAVY30 is offline   Reply With Quote
Old 08-17-2014, 02:28 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Quick One....Oil pressure gauge fitting
Don't quote me 100% on this but if I recall it is 1/8 NPT It is a female on the gauge so your adapter will have to be 1/8 NPT male.
Hope this helps
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 08-17-2014, 02:54 PM   #3
FLYNAVY30
mine is actually a male fitting that will require a female adapter for the braided line. there is a small, copper retaining nut that keeps the gauge in place in the housing. I need to know the size of that retaining nut as the adapter will be the same size. I can probably back the nut off and take it to the hardware store tomorrow, I was just hoping someone might know off the top of their head. Thanks for the help.
Old 08-17-2014, 03:07 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Here are some photos of a NOS 60 lb oil pressure gauge. If I am following you correctly, the nut on the outside is to hold the gauge to the small tin. That is all the threads on the outer side are for.
The inside is where the factory line with the compression fitting /farrel nut would thread into.
If you found a fitting that would thread on the outside with the nut, there would be nothing to stop oil from leaking.
I hope this helps and I am following what you are asking for.
Old 08-17-2014, 03:27 PM   #5
FLYNAVY30
ahhhhh....that is hugely helpful....thank you very much!
Old 08-17-2014, 03:32 PM   #6
FLYNAVY30
just ran down to the garage, and now I am following completely, and yes you are correct....so you think that inside diameter is 1/8 NPT male to a 4 AN male fitting for the line?
http://www.summitracing.com/parts/aer-fbm2512
Old 08-17-2014, 04:02 PM   #7
Jake1971
Jake1971's Avatar
One of our site vendors Leon (LockDoc) makes these copper oil pressure lines. http://67-72chevytrucks.com/vboard/s...d.php?t=613373
The end with the compression nut threads into the factory gauge. Hope this helps.
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 08-17-2014, 04:35 PM   #8
chiefcfd
chiefcfd's Avatar
I looked for this same fitting and never could find it. I don't think it is pipe thread. I wanted to run braided line but just went with the copper line. I hope you can figure this out.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 08-17-2014, 05:45 PM   #9
vidman
vidman's Avatar
My gauge has a 5/16-24 internal thread and 7/16-20 outside thread. just checked my old gauge..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-17-2014, 09:54 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Here is a picture of the fitting that screws into the gauge. It isn't 1/8 inch pipe tread. I don't know of any other fitting that will fit it....
LockDoc
Leon
Old 08-18-2014, 10:27 AM   #11
LockDoc
LockDoc's Avatar
Here is the only way it could be done as far as I can see. If a person would order this fitting:
http://www.andysautosport.com/produc..._17982nos.html
And use this adapter that I made up (the small end fits the back of the gauge and the 1/8” pipe threads on the big end fit the 4-AN adapter that Andy’s Auto Sport sells, then your 4-AN oil line would screw into that. Maybe a person could find a cheaper Female 1/8” pipe to Female 4-AN fitting that didn’t swivel, I don’t know.
LockDoc
Leon
Old 08-18-2014, 10:38 AM   #12
CUSTOM/10
CUSTOM/10's Avatar
I have some of the fittings that LockDoc posted. I bought them a while back from someone on this site.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
