Old 08-21-2014, 12:22 AM   #26
Silvy423
Re: 56 L92 T-10 build started
Few little updates, got the firewall cutout and filler metal welded in. Got all the holes covered and welded up. Painted it with bed liner along with the inner fender's. Cleaned and painted the frame and made new cab mounts. Gonna start making the new tranny mount this week. Should be able to finish the exhaust up also.
Silvy423 is offline   Reply With Quote
Old 08-30-2014, 01:23 PM   #27
Silvy423
When I bought the truck the previous owner hacked the front rad support and used a 1984 rad support. It looked really bad to say the least. Half the battle on this truck is fixing the hack work from the previous owner. Anyway I had to cut the bottom of the inner fenders to clear the newer a-arms and the power steering box, still needs more. Had to trim and cut on the 56 rad support to get it to fit somewhat to the frame. Gonna make some supports for the 56 rad support to the 84 chassis. Everything is really tight but always doable with a cut off wheel and welder. The champion radiator seems nice and has lifetime warranty. Making progress, just SLOW!
Old 08-30-2014, 01:25 PM   #28
Silvy423
Looking for any leads on a harness guy. I know PSI and Seartech will do it, but damn$$$!!. Thought about do it myself but if I can send it off and get it back ready to go for $250, the time for me is critical.
Old 08-30-2014, 04:05 PM   #29
akdg87
akdg87's Avatar
LS performance wiring on facebook, best price and they look awesome.
I just picked up a L92 longblock as well, need to do the DOD delete still.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 08-30-2014, 06:17 PM   #30
Silvy423
Let me know if you need help with part numbers, couldn't believe how much **** you need for the delete. Should be worth it.
Old 08-31-2014, 12:18 PM   #31
akdg87
akdg87's Avatar
I know Brian Tooley Racing sells a complete DOD delete kit for just south of $400 dollars, unless buying parts individually from the dealership is much less?
build thread
2009 CTSV Sedan
Old 08-31-2014, 12:42 PM   #32
Silvy423
That might be your best bet, I used the stock L92 oil pump, they are high volume. I did change the oil pan out for the CTSV pan, perfect for ground clearance.
Old 09-08-2014, 01:04 AM   #33
Silvy423
Well plans changed! Came across a T56 out of a GTO, couldn't pass the chance to have a 6 speed. So out comes the T-10 and in goes the new goods. I'm running a B&M offset shifter which is good for 4" move foward and then I can run a old school Hurst bench seat Chevelle shift stick. Should be good I hope.
[QUOTE]
Old 09-08-2014, 07:51 AM   #34
faribran
I think you will be glad u made the tranny change. Keep us posted with your progress
faribran is offline   Reply With Quote
Old 09-08-2014, 10:21 AM   #35
littlevictories
whatcha gonna do about the funky output flange on the gto unit?
littlevictories is offline   Reply With Quote
Old 09-08-2014, 10:50 AM   #36
Low Elco
Dang this is Bit*hin'! Nice work!
Low Elco is offline   Reply With Quote
Old 09-08-2014, 03:47 PM   #37
Silvy423
Guess I will worry about that down the road when I get to that point. I'm sure the GTO guys have that figured out by now, just use a standard slip yoke. Should be fun!
Old 09-08-2014, 03:49 PM   #38
Silvy423
The Vette headers cleared the T-10 very well, looks like the T-56 is gonna pose some issues. Cutting and welding. It will work someway somehow. I will post pics after I get the Vbands welded up.
Old 09-09-2014, 12:22 AM   #39
Silvy423
Got the headers welded up. Figure once I get it all exactly how I want it I will send it off for jet hot coating. I ordered a 24" long 3.5" in and out muffler. It will be a dual 3" out of the headers to a y pipe into the muffler and then the single out just in front of the rear axle.
Tranny shifter sits pretty far back, no big SUPRISE. I will end up running a Hurst bench set shifter handle to clear the the seat. I also plan to notch the seat and modify the frame of the seat for this. Will look nice when I get the leather put on.
Ofcourse my newly made tranny crossmember had to be rebuilt.
Old 09-09-2014, 01:47 AM   #40
littlevictories
i've seen kits that relocate the shifter to grab the shift rails thru the front inspection plate. might look into that. and the output shaft swap and you'll be rollin. lookin for t56 myself. damn expensive chunks of metal they are.
Old 09-09-2014, 02:06 PM   #41
Silvy423
It may have to happen. Keisler is the company that makes the kit. I know it can be done with out taking the tranny apart but it's a bit tricky. Maybe $300 for the kit. To be honest I like the way it feels with the handle farther back, maybe 4-5" infront of the seat for the ball would be great.
Old 09-09-2014, 02:17 PM   #42
1980c-10 mybaby
1980c-10 mybaby's Avatar
If the input shaft for the driveshaft comes out of the t56 you can use a turbo 350 driveshaft 27spline input shaft.
we just swapped a ws6 ls1/t56 into my buddies 240 and we used a turbo 350 driveshaft
the input shafts could be different but worth a shot
1980c-10 mybaby
1980c-10 mybaby is offline   Reply With Quote
Old 09-09-2014, 06:59 PM   #43
Silvy423
Good to know! The CTSV has the non removable yoke. The GTO just slides out, I will try the T350 yoke. Thanks again
Old 09-09-2014, 07:46 PM   #44
1980c-10 mybaby
yeah no problem boss ill be hoping the 4l60e uses a 27 spline so I can throw it in the 69 burbran im picking up
1980c-10 mybaby
Old 10-26-2014, 10:49 PM   #45
Silvy423
Got the intake all finished, l think it looks good. Ran new power steering lines. Found some rad hoses that fit nice, I figure why not take the time and get hoses that look like they belong. I also got all the fuel lines run and pump and filter. I should have my harness back sometime this week and I can fire it up!
Old 10-26-2014, 10:56 PM   #46
Silvy423
Old 10-27-2014, 08:14 PM   #47
dec010974
dec010974's Avatar
Hello to all. Silvy423, very clean install. You, my man area true professional.
dec010974 is offline   Reply With Quote
Old 10-28-2014, 01:28 AM   #48
bh86
awesome build
bh86 is offline   Reply With Quote
Old 10-28-2014, 11:11 PM   #49
Silvy423
thanks guys its coming along. I plan to tackle the new brakes this week and get it started with some video!
Old 11-18-2014, 07:19 PM   #50
Silvy423
Got her started up!!! 4 link is on order
Check out the link
http://youtu.be/f2K9PrD8GpQ
