Old 08-21-2014, 02:14 AM   #1
crazychevyc10
how hard is it to do a front drum to disc brake conversion?
i currently have a '68 c10 long bed with drums front and rear and wanted to,know how hard it was to do a front disc brake conversion? will i need to upgrade the master cyclinder too? also is it ok to,do the front,first before the rear?
crazychevyc10 is offline   Reply With Quote
Old 08-21-2014, 02:58 AM   #2
Ozzy2013
Ozzy2013's Avatar
Re: how hard is it to do a front drum to disc brake conversion?
Its a fair amount of work if you are not mechanically inclined you might want to pay someone to do it .If you are handy with a wrench sure you can do it plenty of info right here look it up under the archived forums.Yes you need to upgrade the master cyl and proportioning valve.Yes you can do the front first.
Ozzy2013 is offline   Reply With Quote
Old 08-21-2014, 07:08 AM   #3
Mr Handy
Mr Handy's Avatar
The hardest part of the swap is getting the ball joints apart to swap out the spindles up front. I would also recommend picking up a set of flare nut wrenches for working on your brake lines.
The amount of work it takes is worth it. I was able to do the swap and replace all the suspension in my truck in a weekend with the help of a knowledgeable friend.. I did drop spindles, disks up front, new mc, prop valve, springs and shocks all around, new bushing in rear trailing arms, ball joints up front, track bar and shock relocators out back. remember when you should have the alignment checked, I would ask around in your area if there is an alignment shop that all the car guys use.
Mr Handy is offline   Reply With Quote
Old 08-21-2014, 07:14 AM   #4
hugger6933
If you can follow simple instructions I would call it about a 4 on the difficulty scale. The only special tools you will need are a pickle fork for separating the ball joints and flared wrenches for the use on the brake lines so as not to round the over. For the rest of it you could be following a post or reading along in a shop manual to get the play by play on what to do or there is always some one here to help out if you get stuck. Jim
hugger6933 is offline   Reply With Quote
Old 08-21-2014, 08:33 AM   #5
colgad
colgad's Avatar
Mr. Handy, where have you been? We would like to see pics of your newly lowered truck.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-21-2014, 10:41 AM   #6
nlped
nlped's Avatar
Keith has done a great write up on exactly what parts, pieces etc are needed for this swap...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-21-2014, 10:54 AM   #7
boraxman
Keepin an eye out
boraxman's Avatar
Its not to terrible, just make sure you have some muscles, a BFH and a ball joint separator, follow the write ups and get an alignment when done/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-21-2014, 11:03 AM   #8
boraxman
Keepin an eye out
boraxman's Avatar
To add, you should get all your parts together first and have a plan. I wuld buy a later model master/booster as well as prop valve. Yo will need new or adapt the front brake lines in. I would keep the rears drum...Have fun.
ZIP 91351
Old 08-21-2014, 11:37 AM   #9
knomadd
knomadd's Avatar
Take your time, and don't rush through it. If you have a hard deadline, make sure you have some help, preferably someone who knows what to do. Otherwise, I'd wait until you have enough time to get it done. It can take a weekend, or a few. It all depends on your skill set and the tools you have to do the job. It's not so hard that I'd say pay someone to do it, unless you're not at all mechanically inclined, like previously posted. Good luck!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-21-2014, 12:05 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Use 63-70 conversion spindles.
Add a 71-72 M/C and a disc brake prop valve (or aftermarket equals).
I use ECE conversion brake hoses.
Bend new steel lines to connect to the new prop valve.
Done.
The key is disassembling EVERYTHING.
And inspecting and replacing parts that need it.
This includes all suspension parts and steering parts.
Keith
Convert to disc brakes.
Old 08-21-2014, 04:52 PM   #11
no1udknow
no1udknow's Avatar
It's not too hard if you use a setup from a 73-87 c10. If you can get the entire suspension and cross member, it nearly bolts right in and you don't have to disassemble the ball joints or springs. I just did this mod, check my signature for the link to my build. I had the front clip and motor/trans out so it only took about 2 hours to swap.
Things to note:
you will need to drill 1 hole on each side where it mounts to the frame and wallow out 2 others on each side (minor work takes about 5 minutes)
If you want to remain 6 lug, you need to find a 73-87 c10 that has 1 1/4" thick rotors not the 1"thick. (they usually say "HD Brakes" on the option sticker in the glove box) then you can purchase and install the after market 6 lug rotors. Otherwise if you want to run 5 lug you can use any of them but you will need to find axles for the back or a rear end.
other than that, the 73-87 square body trucks are readily available at the junk yard and if you can get a complete front crossmember/control arm set up, the cross member bolts in, the pitman arm lines up, and the steering arm lines up. very easy swap in my opinion. only about 20 or so bolts.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 08-21-2014, 05:00 PM   #12
no1udknow
no1udknow's Avatar
I was lucky though, I also got the complete brake system including master, lines, and prop valve, all of which mounted to the original 68 frame with little work, the only thing I have had to do was get a piece of steel line and a reducer to hook the rear drum brakes to the prop valve.
Built not bought!
