Old 08-20-2014, 09:32 PM   #1
Skunksmash
Skunksmash's Avatar
Adding sway bars, a few questions
I think I'd like to add front and rear sway bars to my truck. It has way too much body roll when you take a corner just a little too fast. Its got new shocks on it, but that really didn't help that much. What are the disadvantages of having both sway bars? Does it ride any rougher? And how hard is the installation? Never done it
Skunksmash is offline   Reply With Quote
Old 08-20-2014, 09:39 PM   #2
E.D.75GMC
E.D.75GMC's Avatar
Re: Adding sway bars, a few questions
I took a front sway bar off of a parts truck, painted it, then installed it on mine. The mounting holes were already drilled in the frame + A arms so it was an easy install.
E.D.75GMC is offline   Reply With Quote
Old 08-20-2014, 10:30 PM   #3
Jake Wade
Jake Wade's Avatar
I upgraded my factory 1 1/16 front sway bar to a 1 1/4 off a 3/4 ton Suburban along with urethane bushings....big improvement.
Jake Wade is offline   Reply With Quote
Old 08-21-2014, 08:18 AM   #4
Rich84
Rich84's Avatar
Adding the front sway bar was one of the best upgrades that I ever did to my truck. Hard to believe they sold them without it...And it was only $20.00 at the junkyard.
Rich84 is offline   Reply With Quote
Old 08-21-2014, 09:33 AM   #5
Lost81c10
Lost81c10's Avatar
I added one to the front, 1 1/16 from a junk yard, $15 with the brackets and bought new moog bushings/new bolts and it was a big difference compared to not having one. Install was about 15 minutes, as previously mentioned, since all the holes are already there for you to just bolt it on. As for the ride quality, it does not feel harsh at all it just feels more snug. I don’t have a rear one but i am still looking for one (still researching which ones can fit my 85) but I can just imagine how much a difference it will make in the rear.
Mando
Lost81c10 is offline   Reply With Quote
Old 08-21-2014, 09:40 AM   #6
hatzie
Moderator
hatzie's Avatar
I believe GM only did rear sways on the 3/4 and 1 ton chassis or maybe only the 1 ton...
There are aftermarket rear swaybars tho.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-21-2014, 10:50 AM   #7
monte0185
monte0185's Avatar
1 tons have the rear sway bars. you can grab them off a dually and bolt them up pretty easily.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 08-21-2014, 08:11 PM   #8
Skunksmash
Skunksmash's Avatar
Can I trouble anybody to take a picture of these mounting holes? Someone said they're on the A-arm itself? Are they threaded?
Old 08-21-2014, 08:57 PM   #9
Skunksmash
Skunksmash's Avatar
Also were the factory ones that I can find at the junkyard, the 1-1/4" ones? Or do you have to get those somewhere else?
Old 08-21-2014, 10:03 PM   #10
Jake Wade
Jake Wade's Avatar
They are not threaded. The holes should be there for a 3/8" bolt/nut configuration.
Old 08-21-2014, 10:24 PM   #11
Lost81c10
Lost81c10's Avatar
here you go.
not threaded.
Old 08-21-2014, 11:51 PM   #12
SCOTI
SCOTI's Avatar
As mentioned, find a bar from a HD app (burb, 3/4, or 1-ton truck). 1.250", solid, & cheap. Add Moog or Energy Suspension poly bushings to help effectiveness.
Do the front first as it will have the largest impact. I would only seek out a rear bar if you feel its needed after the front is done.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
