Old 08-22-2014, 07:18 PM   #1
evan396
brakes?
hi everyone my dad and i are starting to put our brakes back on our 1966 k20. we put the new wheel cylinders on and ran into our frst problem. if you can see in the picture the tabs are up on one backing plate and down on the other. we would like to know if we can press the tabs down to clear the wheel cylinders? thanks evan396Name:  IMG_0041.jpg
evan396 is offline   Reply With Quote
Old 08-23-2014, 12:22 PM   #2
61K10
61K10's Avatar
Re: brakes?
the one on the left looks broken. what clearance problems are you having?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-23-2014, 12:41 PM   #3
evan396
Re: brakes?
The one on the left is lower. It does look like somebody hit it down. The one on the right look's like it is to high. It is right up against the rubber boot on the wheel cylinder. I am concerned that the boot is going to rip when in use. Thanks evan396
Old 08-23-2014, 12:50 PM   #4
61K10
61K10's Avatar
Re: brakes?
my 1/2 ton ones rub on the rubber end caps. they must be there for a reason?
1961 chevy K10
Old 08-23-2014, 01:03 PM   #5
63burban
Chevy addict
Re: brakes?
The tabs are against the rubber boots to help keep them on and to help support the wheel cylinder when the brakes are applied. Everything inside the drum wants to follow the drum around when the brakes are applied.
63burban is offline   Reply With Quote
Old 08-23-2014, 01:08 PM   #6
61K10
61K10's Avatar
Re: brakes?
pic
1961 chevy K10
Old 08-23-2014, 02:35 PM   #7
evan396
Re: brakes?
Thanks, I guess we will have to bend the tabs back up. Thanks again everyone, evan396
Old 08-23-2014, 06:57 PM   #8
jtrichard
Re: brakes?
The tabs are there to keep the pistons from blowing out if it gets so far out of adjustment or some kind of catastrophic failure broken drum ECT.
jtrichard is offline   Reply With Quote
