drive shaft ?
What year and model drive shafts will fit in a 72 c20 350 4peed I've gone through 3 carrier bearings in
Re: drive shaft ?
Your losing carrier bearings because your drive shaft is out of balance.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Sep 2005
Re: drive shaft ?
Have a drive shaft shop replace the carrier bearing ujoints and balance the shaft.
the boat guy
Re: drive shaft ?
What they said.
If you do a search you will find a few dozen results of people with the exact problem you have and the various solutions. Some people have had luck swappiing driveshafts from other vehicles. If your truck is set up exactly like theirs (same engine stands mounted in the same location same wheelbase and same rear end) you might be lucky enough to go to a junkyard and find a car equipped exactly like the one they found that's in useable condition. If that sounds like way too much effort and time to figure out, and it should, you could always have a one piece shaft made to specifically fit your truck. I've had 3 different length driveshafts in my truck and they've all fit.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Re: drive shaft ?
On my 72 C10 LWB I went from a 2 piece shaft to a 1 piece shaft. I ended up with a drive-shaft vibration, had it balanced, still vibrated. Turns out the pinion angle needs to change when you change the position of where the drive-shaft originates (from the carrier bearing vs the trans tail housing). I'm running a very long shaft T400 but still not close enough to the rear cross-member.
It wouldn't shake too bad on flat highway, but when the bed was loaded or when the rear dipped due to an uneven road the vibration got worse. Selective angle shims (made for leaf springs) installed on the trailing arms corrected the angle and the vibration is gone. |
