Old 08-24-2014, 02:15 PM   #26
910506chevy
910506chevy's Avatar
Re: My 1950 Chevy "S-3100" Build (old+new)
Sub'd
91 Silverado
05 Silverado
06 TBSS
910506chevy is offline   Reply With Quote
Old 08-24-2014, 11:18 PM   #27
CaliforniaDaddy
CaliforniaDaddy's Avatar
Originally Posted by ghettoluxury View Post
Sorry I forgot to attach the pic
Oh my oh my!!!!! Did he say why he never used them?
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.”
CaliforniaDaddy is offline   Reply With Quote
Old 08-27-2014, 10:37 AM   #28
CaliforniaDaddy
anyone have an idea on what size tires in going to need to run for the front and rear?
Old 09-03-2014, 09:34 AM   #29
CaliforniaDaddy
Well I got a little bit of work done on the S10 frame yesterday. Nothing exciting.
Old 09-03-2014, 09:39 AM   #30
CaliforniaDaddy
Also finally found a set of 2013 Camaro SS wheels 20"x8.5" front and 20"x10" rear. Tire size is going to be 235-40-20 Front and 255-35-20 Rear.
Old 09-04-2014, 04:02 PM   #31
IWanna49
IWanna49's Avatar
Such nice wheels! I'll definitely be following along on this one. Be interesting to see if you will have any clearance probs on the front. I certainly hope not!!
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 09-05-2014, 09:36 AM   #32
CaliforniaDaddy
Yeah you and me both!
Old 09-05-2014, 09:38 AM   #33
CaliforniaDaddy
Well did a little bit of cutting and grinding and grinding.....and grinding........ Those rear mounts are a pain in the butt.
Old 09-08-2014, 05:26 PM   #34
CaliforniaDaddy
Scored at the junkyard this weekend. Pulled a almost brand new set of Bilteins the HD front sway bar, and the correct E-brake cable I needed all for 60.00!!!!
So I got to work on it.
Old 09-10-2014, 08:44 AM   #35
FarmerSid
FarmerSid's Avatar
Good score!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 09-12-2014, 02:27 AM   #36
CaliforniaDaddy
Worked on the chassis today. Finished removing the old S10 body mounts and made way for the new mounts. Also test fit one of the 20" SS wheels.
Old 09-13-2014, 12:24 AM   #37
CaliforniaDaddy
Well got some more work done today, grinding, welding,cutting,sanding......Got all 4 body mounts tack welded in place on the S10 chassis, and started to remove everything on the the 50, getting ready to pull the cab and check fitment on the new frame.
Old 09-13-2014, 12:25 AM   #38
CaliforniaDaddy
Anyone need a frame????
Old 09-13-2014, 06:02 AM   #39
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Cool build! subd
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 09-13-2014, 06:09 PM   #40
IWanna49
IWanna49's Avatar
So....how did the Camaro wheel test fit go??? Pics???
-Greg
Build thread:
Old 09-13-2014, 06:33 PM   #41
CaliforniaDaddy
Well I'm definitely going to need a 2 1/2 inch spacer front and the rear I might need to swap out the S 10 lugs for the 14 mm Camaro lugs. once I get the body and the sheet-metal back on, I'll be able to check wheel fitment.
Old 09-13-2014, 07:33 PM   #42
CaliforniaDaddy
Today I was able to get the cab resting on the new S10 chassis mounts. Feel pretty good about that. Have a little bit of tweaking to do. Nothing major.
Old 09-13-2014, 07:34 PM   #43
Clay54
In post #16 (3rd picture) and other post also, there is a canister behind the gas tank. Hate to show my ignorance, but what is that? Clay
Clay54 is offline   Reply With Quote
Old 09-13-2014, 08:08 PM   #44
CaliforniaDaddy
That is the S10's charcoal canister (smog stuff)
Old 09-13-2014, 08:59 PM   #45
Clay54
Thanks, my '89 S10 was made for California with all the smog stuff but not sure where that canister is. Might be under the hood somewhere, haven't paid that much attention yet. Thanks for your reply. Clay
Old 09-14-2014, 03:51 PM   #46
CaliforniaDaddy
Need everyone's eyeballs on this one. How does the front wheels look in the wheelwells pretty centered using your eyeballs? I split the tape in the middle at 13 1/2 inches
Old 09-14-2014, 06:51 PM   #47
oldman3
oldman3's Avatar
Looks good, I would rather have it a little forward than back. When it comes down it should look just right...Jim
oldman3 is offline   Reply With Quote
Old 09-14-2014, 07:09 PM   #48
CaliforniaDaddy
yeah that's what I am thinking. I'm going to go have my wheels and tires mounted. So Ill take another picture with those in place. I have 2" drop spindles for the front and 3" blocks for the rear.
Old 09-14-2014, 08:14 PM   #49
IWanna49
IWanna49's Avatar
Looks good! Will like it better with the SS wheels!!
-Greg
Build thread:
Old 09-14-2014, 09:50 PM   #50
BlueJeep
BlueJeep's Avatar
Put the spindles on first, and put the largest diameter tires on that you have to gauge where they should go (I used 235/75R15's when I did mine). Also put the hood on too, these fenders can be up or down 2" in the front and you wouldn't know without the hood being on and the hood gaps fairly close.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
