Old 08-26-2014, 09:36 AM   #1
84GMC15tepside
84GMC15tepside's Avatar
NP440/A833 Pressure Plate, Help Please!
Hey guys,
I've been putting my 350 engine together and getting ready to drop it in the truck. Currently, I am putting on the flywheel, clutch and pressure plate so I can then mount the NP440 to the engine and then drop it all in the truck. I got my original flywheel resurfaced, and I got the clutch on and pressure plate mounted. While using a clutch alignment tool, I evenly bolted down the 6 pressure plate bolts in a star pattern. The bolts are shoulder bolts and have lock washers on them (The shoulder bolts and lock washers look original to the truck). Being shoulder bolts, the shoulder is supposed to stop the bolt from going in the provisioned flywheel holes once the shoulder hits the flywheel... but probably because it's the original flywheel, the shoulder continues to go in the flywheel holes when tightening down some of the bolts...
1. I don't think so (because of the shoulder bolts), but should the pressure plate be flat against the flywheel?
2. I assumed not to the above question... So I used a flat washer off my work bench as a thickness gauge. I tightened down one of the bolts until the shoulder hit the flywheel and I stuck the flat washer between the flywheel and P.P. while tightening the bolt until the flat washer was almost stuck. I yanked the flat washer out and went to the next bolt (in a star pattern)... until all 6 bolts were tightened down and the distance between the P.P. and flywheel at each bolt were the thickness of the flat washer. Is this an OK method to use? (By doing this the pressure plate is an even distance from the flywheel all around, and the lock washers should hold the bolts in place)
Sorry for the long thread, I'm just trying to make it as clear as possible!
MY6 Stepside
84GMC15tepside is offline   Reply With Quote
Old 08-26-2014, 02:22 PM   #2
geezer#99
geezer#99's Avatar
Re: NP440/A833 Pressure Plate, Help Please!
THe pp needs to be bolted down flush to the flywheel. No spacers or washers.
Do yours look like these in the link.
http://www.jegs.com/i/McLeod/673/150...ductId=1713332
Old 08-26-2014, 09:10 PM   #3
84GMC15tepside
Yes they do look exactly like that... This is what I was doing before with the flat washer.
But I ended up talking to some experienced guys from town and they said the same thing, for the PP to be flush against the flywheel. I took off the PP and clutch to examine the flywheel bolt holes more closely. It ends up that the threads in the flywheel holes don't start until approximately a quarter of the way thru the flywheel... basically the length of the shoulder. So I mounted everything back together and made it flush...
I got some help from a couple buddies and we attached the tranny and put it all in the truck!
MY6 Stepside
