Old 08-27-2014, 12:19 PM   #1
drive.1968
drive.1968's Avatar
67-72 Frame cross members
Hello all,
I am building a 68 SWB with no markers. I have decided to use the frame that has the the least damage and already has disc brakes, however I realized that this frame has an extra cross member directly under the fire wall. It is riveted in so it is a factory modification. Is this extra cross member between the front A frame mount and the transmission mount needed? It appears to be directly where the engine flywheel will mount to the the turbo 400!!! Was this mount for a straight six engine? I have went through the Chevrolet Truck Chassis Service Manual and it does not call out this particular mount and this mount is not on my 68 LWB that came with 307 and a turbo 400 transmission.
drive.1968 is offline   Reply With Quote
Old 08-27-2014, 12:43 PM   #2
Doug's68SS
Re: 67-72 Frame cross members
Yes 6 Cly a friend has a 69 with the straight 6 as is swapping top a V8 and his has the cross member. you will need to remove it.
Doug's68SS is offline   Reply With Quote
Old 08-27-2014, 12:59 PM   #3
67c10rustbuket
67c10rustbuket's Avatar
The cross member is for manual transmissions, they used bell housing mounts rather than tail shaft cross member mount like the automatics. They are found on both I6 and V8 trucks. cut the rivets and remove it. It will not fit with an automatic trans in place.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-27-2014, 03:07 PM   #4
drive.1968
drive.1968's Avatar
Cool!!! Thank you for the input
Old 08-27-2014, 08:38 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by 67c10rustbuket View Post
the cross member is for manual transmissions, they used bell housing mounts rather than tail shaft cross member mount like the automatics. They are found on both i6 and v8 trucks. Cut the rivets and remove it. It will not fit with an automatic trans in place.
x2
WIDESIDE72 is offline   Reply With Quote
Old 08-28-2014, 02:42 PM   #6
drive.1968
drive.1968's Avatar
Originally Posted by WIDESIDE72 View Post
x2
Yes, I have no idea what year the frame is figure somewhere between 69-71
